Tie Rod Ends
Looking around for a pair of new tie rod ends. Prefer to buy new OE, but looks like NLA. I also tried aftermarket and was not able to find any in stock.
I appreciate any leads.
1991 SVX L JDM |
Re: Tie Rod Ends
Have you read this: https://www.subaru-svx.net/forum/sho...light=tie+rods
Re: Tie Rod Ends
Thanks Blacky. I had posted in that thread as I was excited to see the interchange for the inner tie rods. I am hoping to track down the outer ends as I see the Beck Arnley appears to be out of stock most places (101-4470 & 101-4469). I have an inquiry in with my local parts store to check with Beck Arnley.
1991 SVX L JDM |
Re: Tie Rod Ends
For now, tie rod of my SVX is fine, but it's a consumable item, so I'm interesting in it's available or not.
Re: Tie Rod Ends
I was able to find one right side tie rod end and source it from a Subaru dealer who had it on the shelf. Keeping my eye out for an OE left side to have for when mine wears out.
1991 SVX L JDM |
Re: Tie Rod Ends
I contacted Beck Arnley, who stated that 101-4469 & 101-4470 are NLA.
Now its time to look at alternatives.
1991 SVX L JDM |
Re: Tie Rod Ends
So, we maybe able to contact Sankei to find compatible parts though it has no SVX parts officially. This is the company which I bought inner tie-rod. https://ansin1.net/sankei-555-com/contact/ |
Re: Tie Rod Ends
Good idea. I looked around online and measured the new OE right unit once it arrived. 14mm x1.5 thread coming in from the inner tie rod, 12 x 1.25 going into the hub.
By crawling the 555 parts listings, and ebay, I'm guessing 555 Sankei SE-t021L & se-t021R may work. These are parts to fit the 05-11 Yaris and others, one OE Toyota part that comes up similar is 45047-59135. I found a se-t021r on ebay for $26, so I'm ordering that to compare side by side with the new OE unit I got from Subaru. I also have a replacement steering rack off my car that I can play with/test fit. I'll post my findings once the part arrives.
1991 SVX L JDM |
Re: Tie Rod Ends
Excellent. I'm closing in on 300,000 km and I know my front end needs work.
Re: Tie Rod Ends
It sells for around JPY 2,000 (USD14) in Japan and is easily available. |
Re: Tie Rod Ends
I am not sure this Yaris tie rod will work. It appears to be a couple inches too long, but I will check the adjustment range and report back.
1991 SVX L JDM |
Re: Tie Rod Ends
It may be adjustable if it is less than 1 inch. If it's too longer, you may need to replace it with a shorter inner tie rod. And.... https://size.name/en/products/45046 According this, spec of 45047-59135 you bought are as follows. LT(full length):173 mm th(tie rod thread):FM14X1.5R C(cone diameter):12.6 mm cr(cone slope):1/6 tp(finger thread size):MM12X1.25R However, th shoud be MM16x1.5R. Isn't right? Last edited by Noriyasu; 03-10-2024 at 09:27 AM. |
Re: Tie Rod Ends
I need to use the SVX tomorrow, so I connected the battery and started the engine for the first time in a while.
When I lifted the car up and did a quick inspection, I measured the length of the tie rod end. LT(full length):145 mm th(tie rod thread):FM16X1.5R tp(finger thread size):MM12X1.25R Suitable tie-rod end seems as follows. https://size.name/en/catalog/rulevye...9&th=FM16X1.5R If it's BMW or Toyota, Toyota may be more likely to fit it. 45046-49125(TOYOTA) SE-T491L(555-SANKI) 45047-49055(TOYOTA) SE-T491R(555-SANKI) It's relatively cheap, so I'll give it a try. I'll report back if it seems like a good fit. |
