Old 02-11-2024, 03:52 AM
Originally Posted by Noriyasu View Post
Previously, a similar floor was being coating on a Discovery Channel program called Garage-Rehab.
The epoxy paint used to be sold on Amazon, but it doesn't seem to be available anymore.
My 1st garage floor is also epoxy paint, but it's just green like many old type maintenance shops in Japan.
BTW, it looks like you're replacing the timing belt. As you may have experienced several times already, the bolts between the crank pulley and cam pulley are very tight.
You may need a crank pulley wrench and a cam pulley wrench for your Subaru Boxer Engine.
If you replace the camshaft oil seal (which is recommended), it's helpful to have a sprocket holder to keep the left bank cam from turning and crushing the pistons and valves.
When the engine is at #1 top dead center, the right cam is free, but the left camshaft is pressed by the valve spring and will move when the belt is removed.
Good Luck.
Thanks Noriyasu. I do need to get a new cam holding tool. I'll pick something up before doing the job. Its been about 13 years since the last time I did the timing belt on an SVX, so it'll be interesting to get reacquainted with the job again.
Today, I installed the right valve cover, and after much dithering, pulled the left cover. The AC line on RHD cars limits the access much further. I ended up pulling the bolts from the compressor and pulling off the starter wiring in order to get more wiggle room. I'm glad to be getting this done. The valve covers were both leaking.
Old 02-18-2024, 05:04 PM
Yesterday, I re-wrapped portions of the engine wiring harness, reassembled some of the engine bay, replaced some a/c O-rings, and ordered a new AC drier.
I noticed the plug on injector #4 lost its little nib that keeps the plug on. I may try repairing the nib before I replace the injector for this issue alone.
I'm waiting on a large parts order to come in at the dealer relating to my upcoming timing belt service. Depending on when that arrives, I may move on to extracting the dashboard and heater core before I do more work under the hood. We'll see!
Old 02-19-2024, 11:26 AM
SVX_MY_BABY's Avatar
Yesterday, I and ordered a new AC drier.
Let us know if it fits. I've ordered 3 after market ones that haven't fit.
Peter
Old 02-19-2024, 10:17 PM
Noriyasu Noriyasu is offline
It's a warm day today. The forecast is for rain and snow to after tomorrow.
Almost of snow around the garden and garage has melted, so today I'm recharging the batteries of my SUBARUs, which don't used in snow season.
The batteries are in good condition, but I will be charging 3 devices for 2-3 hours each just in case.
Old 02-21-2024, 01:53 PM
Last night, I pulled the console and instrument cluster out of my SVX, and started remove the dashboard for the heater core repair.
I still have the intake, battery, and throttle body on the bench. Waiting on engine seals and hoses before I continue with the engine-related maintenance.
Old 02-22-2024, 03:18 AM
Pulled the dashboard from my SVX today. I've done it, a long time ago, but its still a challenging job. Followed the FSM = made the job seem easier than in the past. I recommend two people to lift out the dash. Very challenging to lift it out solo.
Onto the steering support beam, evaporator and heater core.
Old 02-22-2024, 02:53 PM
any chance of
Peter
Old 02-22-2024, 08:10 PM
Removing the dashboard is one of the last things I want to do. The dashboard of my other Subaru is sticky and I would like to replace it if possible, but it would be a very difficult task.
Anyway, once it's removed you'll have easy access to the cruise control ECU.
Old 02-24-2024, 02:21 AM
The shape/depth of the SVX dash makes it particularly awkward to lift out of place. This time, I dropped the steering column down, but, didn't have the seat slid all the way back before the battery was disconnected. Following the FSM and dropping the column made the job much easier than when I had done it in the past.
Today, picked up rear struts and a small mountain of seals, hoses and clamps from the dealer. More supplies for the heater repair and timing belt service.
I hope to have the heater box/core out of the car this week. Steering beam and aircon box must come out, next.
Old 02-24-2024, 09:53 AM
wdb wdb is offline
dances with roads
Well wow, that's ambitious! I'm impressed.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 02-26-2024, 02:22 AM
Extracted the heater core box and pulled the core from the box. Evidence of coolant residue on the core, so the unit was definitely leaking. I'll be brining the heater core itself to a radiator shop, with the intention of getting something fabricated as a replacement.
Old 03-03-2024, 03:17 PM
During the forum's downtime this week:
I brought my heater core to a fabrication shop, actually two shops: one for the tubing and another to make the core itself and braze/weld on the tubes. I am replacing the plastic/aluminum core with a brass unit that should give a much longer service life. The shop was puzzled why Id go through the effort with an old Subaru . Hopefully the shop does a nice job with the unit and it fits into the heater box properly.
Yesterday, I replaced the original, hardened PCV hoses. These are still available from Subaru:
807415082
807412172
807519082
I had to chip the short lower hose off. I doubt it was sealing.
Today, I may replace the short flexible ATF hoses between the engine and transmission, and may attempt to fashion a replacement to the coolant TB hoses from universal hose.
Old 03-03-2024, 08:09 PM
807415082
807412172
807519082
It' better idea to replace these if it still available. I have something to go to the SUBARU dealer next week, so I'll order these.
How about 807520162 , 807412132 and 807412142 ? Was it discontinued ?
Old 03-03-2024, 10:12 PM
Unfortunately, most of those parts were discontinued in Japan. I was only able to order two. Anyway, thanks. Basically, I do not touch any hose if there are no issue. It will make leak trouble.
Old 03-04-2024, 03:57 AM
I did successfully replace the two flexible hoses between engine and transmission today.
I have not attempted to source the two longer hoses.
Which of the hoses are you unable to get, Noriyasu?
Display Modes
