Re: Bontrager Works 22mm rear anti-sway bar kits (1/15/18)
94 SVX LSI- Rebuilt engine, 4.44 with trans cooler, Quick Change Shift Kit, SS exhaust with Magnaflow muffler, 08 STI Wheels, K&N Filter, and still adding. |
Correct, the rear swaybar endlinks connect to the hub itself, not on the struts like the front bar. This is a MUCH sturdier design, thankfully.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
I'm in for a sway bar kit.
Plus I like this forum better then face book you can do search and read in a list form a lot better. Also will the y pipe work as good as going two intake pipes and mafs I'm putting two hood scope on my glass hood was going two mafs and forced air Lane makes a chip for two. Thanks Jim |
I have an ecutune 1v5 chip in my car.
not all together its just lan (aka long ass name)he has been making chips and blowers, trans, here on the svx net for ever his known also a subiechips on the web
http://www.subiechips.com/index.htm looking forward to a sway bar. Last edited by svxnavyvet; 01-16-2018 at 05:31 PM. |
Ok, then yes I am familiar with LAN. (Mike??) He has sent me a few parts over the years and I have been quite happy with them!
Will you be making any extra? Ive been dreaming of having both the intake and RSB but im a a little tight on money....atleast until tax return comes in.
1992 SVX LS 2002 Park Avenue 2008 328i convertible 1993 GMC C1500 W/T Last edited by DallasSVX92; 01-17-2018 at 07:09 PM. |
Nevin, Can you offer any further updates on the new endlinks you have. Those who still have your original RSB might want to upgrade from the ones you first offered. I think your new ones are a bit shorter and not as prone to rattling and loosening with age. I replaced my noisty originals with QS Chromoly Teflon Kevlar ones, but they too become noisy. Was going to add end link boots to them filled with grease. Are you still using the MOOG K90520? Any info would be of interest, John
John, I am no longer using the QS components pieces.
I am using a similar offering from another company. I can easily get you the newer ones and they are a similar design and will eventually also start to rattle but they will last much longer. I can easily sell someone new links every few years for a few dollars and we can call it a wear item, but these were not designed for comfort in mind, so i havent been looking for another style becaise I don't want to give up performance at all. Pm me if you have questions.
Posted up the bars in the Group Buy section today!
Here is the link. http://www.subaru-svx.net/forum/show...990#post747990 Happy Driving!
I'm still runnning the original set of endlinks from when I got in on your first run of sway bars. They are noisy but as long as they aren't going to fail I just turn the radio up. At 306k there are so many creaks and rattles in the car it doesn't even bother me. I still love how flat the car corners compared to stock. I would never go back to a smaller sway bar. Thank you for making my svx so much better!
Thank you, Sam
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
#28
I wanted to be part of this purchase but my car was involved in a major front end accident and I'm still trying to put it back on the road. But I have a question about just upgrading the rear sway bar; how does this affect driving? My understanding is that increasing the rear sway bar will increase either over steer or under steer (don't remember which). I'd like to decrease body sway while turning but without increasing either over/under steer.
#29
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
