crankshaft pulley
I need to replace the crankshaft pulley for the third time. Does anyone have a better replacement than the Subaru OEM pulley? There are numerous lightweight
OEM size (not under drive)for the other Subaru 2/2.5 l engines but nothing I have found for our 3.3l SVX engines. Any suggestions other than OEM Subaru, which has failed for the third time!!! |
Re: crankshaft pulley
There may be something else causing the failures. I never replaced a pulley on any of my 3 SVX and one of them had nearly 400,000 km. The '97 I am driving is close to 300,000 km.
The 2.5 pulley is the same I believe.
I did a search for crankshaft pulleys and found numerous posts about failures so I don't think this is caused by anything but design/manufacture problems, since the cause is almost always the separation of the rubber damper. I want to change to a one piece design and it seems that the pulleys from all models (legacy/impreza/outback/forester/WRX, STI? 2/2.5l) can be swapped even though they don't have a rubber damper; one post even has a quote from SOA concerning the damper where SOA says the damper is not needed because the SVX (all) boxer engines are INTERNALLY balanced. I don't want an under drive (Smaller) pulley but I could use a lightened OEM sized pulley; when I look at the lightened pulleys on Ebay for other Subaru models, they all look like they are not the same outside diameter as the OEM SVX pulley; they look smaller. Any recommendations or suggestions for an OEM SVX sized lightened pulley?
All of the EJ pulleys are the same as the EG33. so any light oem sized one piece pulley for the EJ22,25 etc will work I personally have the Perrin https://www.perrin.com/shop/engine/l...ey-for-wrx-sti
Unfortunately, the Perrin pulley is out of stock.
https://www.ebay.com/itm/Perrin-Ligh...LH_TitleDesc=0
Same part# Close to you also in Pawtucket, RI. There are 37 on Ebay as low as $94.35
1997 Bordeaux Pearl, 2006 Alfa Romeo Brera 3.2 6MT, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, Last edited by Blacky; 07-25-2018 at 07:09 PM. |
If you click the red box they are still in stock. same product, but a different color.
MY pulley is red, for some reason it defaults to black when you click the link. . Last edited by svxcess; 07-26-2018 at 11:41 AM. |
Thank you everyone for your input. Since this is my daily driver I needed to get it back on the road quickly. I was able to get a pulley, in stock, from a local Auto Zone that was listed for a 93 Legacy for $50. I will purchase a Perrin pulley so that when I change my timing belt in a few months, I will just swap the new one piece pulley and keep the Auto Zone as a spare for my other SVX.
I thought I was finished w/this thread but while checking pulleys on Ebay, I came across a listing for a pilled set that included the power steering/alternator/ crankshaft pulleys, but for the BRZ. Since the pulleys on every other Subaru model are the same, is this true also for the BRZ? I;m really only interested in adding the power steering pulley since the Perrin pulley seems the pulley of choice but a complete matching set would look nice,
Just want to chime in and say I have had the Perrin Lightweight Crank Pulley from my old Impreza RS installed in my SVX for years now.
Thanks for the BRZ info.
