Re: Smoke from engine compartment. Please help.
You leaking oil from the side(s) of the motor onto the exhaust headers? Valve cover gaskets shot?
Valve cover gaskets were one the first things I had to change when I bought mine.. |
That's what it seems to be but I can't tell for sure as I'm not a mechanic. So I'm unsure. It's leaking oil pretty good tho. Also, when I pulled into work as I parked the car it stalled. Wonderful.
Welcome to the wonderful world of SVX ownership.
I read your story, I understand completely, I got lucky and my svx was in good condition, the trans did have some problems/issues which I did not get sorted out in time and eventually it did fail, but I got 5 years out of it and had always planned on manual swapping, the rest of the car I put money into upgrades not too much into maintenance, though now I really need to do some lol
We sanded out the rust. And spraypainted over the open metal to prevent more rust. It look horrible. This doesn't look great, but it's much better than before. I'm going to eventually rent the tools necessary to redo the sides. Anyone have any objections to using Lucas oil stop Leak to help with my gasket leak issues. Not as a permanent fix but something to buy me some time. |
Visually mine is mostly stock very few things look better, but its lowered with coilovers has 18" rims/tires and all led tail light conversion. ![]() |
Is it normal that the whole car vibrates when it's in drive or reverse? The only other car I've seen do this is my girlfriends old geo prism that had over 200k on it haha
no not normal, is it while driving or just putting it into gear causes it?
could be motor mounts or transmission mount is worn out |
It's when the car is stationary. When I put it in neutral or park it's soft. But when placed in gear (drive or reverse) it vibrates and then smooths out when I accelerate and start driving. It's not the acting of placing it in gear like my other car that lurches when I shift to drive or reverse. It's when the car Is in gear and sitting there, it's vibrating.
