Old 06-18-2015, 03:12 PM
Went to go pick the car up today even though they said it "wasn't idling right". I figured it was just being temperamental so I go to give it a run and no, it's still running the way it was before.
The guy said "at speed it's fine", which I am going to take with a few grains and just assume they didn't fix anything.
Old 06-19-2015, 09:12 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Re: Brand new problem (scary!)
Sooooooooo did you ever inspect your cats??
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 06-19-2015, 11:43 PM
Cats have not been pulled.
We did a pressure test on the exhaust and found there was little back pressure. The engine is running very rich though, so I think if the cats are clogged there is another problem causing that.
Suspect of the moment is the z32 maf. Looking for a good one to swap in.
Today I found my intake snorkus is falling apart more than usual at the cam breather, but I would think a leak would cause a lean condition.
Old 06-29-2015, 06:16 PM
I'm at the shop right now, threw a new maf in, no change.
The guy says they put a scope into the cats and visually inspected them. They look ok.
I put in some new chips a couple weeks before this went to ****, so today I swapped the old chips in and when the battery charges we'll run it again to see how things go. Don't have high hopes but we're just out of ideas.
Old 06-29-2015, 08:12 PM
michael's Avatar
michael michael is offline
What Potholes ???
Do you have a spare computer laying around?
Wanted: Steering Wheel
Old 06-29-2015, 10:58 PM
Switching back to the old ECUTune chips had no effect. Visually inspected ECU, looks OK.
I don't have a spare.
Video from today: https://www.youtube.com/watch?v=hWEL...ature=youtu.be
Very wobbly at idle, steady at higher RPMs. I think that is what he meant by "at speed it's fine". I don't think he actually drove it but I assumed he did before.
The tach is reading the idle as normal. It's not wobbly from dropping to a low idle.
Old 06-30-2015, 04:06 AM
It sounds like it's running on about 4 cylinders. Also are you sure the engine mounts are alright? That engine sure is jumping around a lot.
Old 06-30-2015, 09:22 AM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
Sure sounds {and looks} like only 4 cylinders to me.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 06-30-2015, 05:45 PM
Engine mounts are practically brand new. They were replaced when the head gaskets were done in November 2013, and the car sat for literally all of 2014. This year it's just been bouncing between shops for upgrades and repairs for 4 months straight.
I will agree it sounds like some cyls aren't firing. I'm going to go back over and pull injectors to see what it does. Last time it did nothing but it's running differently than when the problem arose so maybe we'll find a clue.
Old 06-30-2015, 06:11 PM
michael's Avatar
What Potholes ???
Did you check for voltage leaks from the coils?
Old 06-30-2015, 10:38 PM
Tapani Tapani is offline
There's another member on the forum who looses spark on all passenger side coils when heat soaked in heavy traffic.... replacing the ignitor is of no help. This happens only on idle - higher revs all is fine....
The +12V feed for the coils is separate for the drivers side and the passenger side. The ignitor controls the grounds.....
Have you checked that all coils do get juice?
/T
Old 07-01-2015, 07:48 AM
longassname's Avatar
Just some dude.
Significant Technical Input
For reliable diagnostic connections on an SVX you should get one of my select monitor adapters.
I looked at your log and noticed the following.
Your o2 sensor is bad and is being ignored..isn't your problem
Your left o2 readings are consistently rich. Normally you would see your readings flicker back and forth between rich and lean. Since they are not that means the ECU is not able to get the get the exhaust readings to stoichiometric by shortening the injector on time. This is probably not because you are actually running rich. You are reading unburned oxygen because of the missfire.
I would probably put in a good right o2 sensor now for the following reason. If you put in a good right o2 sensor and log again you should see the afr readings on that side flicker around stoichiometric. If that proves to be the case that will tell you that you have a discrete missfire on a cylinder in the left bank. If it also reads steady rich then you will know you have something more nefarious that is effecting the whole system.
For now you will probably find unplugging the oxygen sensors will greatly improve how the engine runs. It is currently pulling out a lot of fuel because of all the oxygen it is reading on the left side. So you probably have 1 cylinder not firing and 5 cylinders running extremely lean.
To be quick about things and not have to wait for parts I would immediately swap the o2 sensors from left to right so you can get readings on the the right bank. Leave the bad o2 sensor unplugged. Just install it on the left to plug the hole.
...let me know what you find and I'll help you with the next step
So I got JECScan working, watched the numbers change as the engine ran, and what I learned is I have no idea how to use this.
I downloaded EVOScan and got that working as well, actually drove it up and down the street once and created a small datalog. It seemed as though the ECU has trouble keeping up with the logger as it attempted to reconnect 185 times. The car also felt as though it didn't want to move. It kept idle alright, but if I gave it more than a little gas it would bog down. Temperature readings seemed normal after actually moving the vehicle.
In the image below you can see the O2 readings are a bit strange. The numbers slant downward like that because I was shutting those readings down in an attempt to reduce the read load.
If anyone can make heads or tails of this I would appreciate it. In the meantime I suppose I'm either going to go learn to use a multimeter or go eat a cheeseburger and cry a lot.
Old 07-03-2015, 12:20 AM
I tried to get readings today but it's all garbage. There was some sort of error, the computer restarted while it was logging, and after that Evoscan would not load properly and the battery was low anyway.
We disconnected the O2s and the car started without having to push the pedal, but it ran the same otherwise. We were not able to swap the sensors yet. I advised the shop to just install new ones since I seem to have no record of having them replaced.
We pulled injector connectors and observed the same behavior that I reported the first time. Pulling 1, 2, 3, and 5 does nothing. Pulling 4 slowly bogs the engine, pulling 6 bogs it quickly.
The idle seemed to deteriorate even though the tach read normal revs. It seemed by the time we were done scratching our heads it was running on two cylinders.
Judge that for yourself here: https://youtu.be/Adx9T8yJd5U
The revs seem to increase alright when throttle is applied, though I can tell it still isn't 100%.
I'm going to have them run continuity tests on the injector wires.
You mean this or something else?
Old 07-03-2015, 06:13 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
"Four cylinders are decompressed (one only slightly, three on one side) and there's nothing left to check without going into the engine.
Even though they said the spark is good the guy actually doing the work said there is little or no combustion occurring."
Where does this previous info. fit in the scheme of things ? BTW, kudos for your tenaciousness !
Old 07-03-2015, 08:07 AM
I will have to ask very specifically when I check in next week, but I think compression returned when the timing was fixed. The prevailing theory so far is when this problem occurred it caused the belt to skip teeth and the resulting fuel dump killed the 02 sensor or it was gone already.
