Old 12-19-2014, 08:21 PM
Traitor_Moron's Avatar
Traitor_Moron Traitor_Moron is offline
BoreD'oh Poseur Faux Pas
Christmas tree lights?
It's been a long time and please forgive me but I don't remember what causes this... Please refresh my memory. I humbly thank you.
Jeremy
1994 Subaru SVX LSi - Laguna Blue Pearl - sold
1994 Subaru SVX LSi - Emerald Green Pearl - sold
1996 Subaru SVX LSi - Bordeaux Pearl - traded
1996 Subaru SVX LSi - Bordeaux Pearl - sold
1994 Nissan 300zx Convertible - Emerald - 102k mi
1999 Mercedes SLK230 Sport - Brilliant Silver - 83k mi
1990 Ford Taurus SHO - Oxford White - 10k mi
Old 12-19-2014, 08:25 PM
Re: Christmas tree lights?
I would say alternator is most likely cause.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 12-19-2014, 08:31 PM
Tis the season for a new alternator or perhaps your crank pulley has separated.
Old 12-20-2014, 04:25 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Buy yourself a volt meter that plugs into your cigarette lighter. Harbor freight has them for cheap. You should see around 12V before cranking and around 13-14V once the engine is running. If you see no difference, check your belt, pulley and have the alternator checked at Auto Zone or Pep Boyz. Good luck!
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 12-20-2014, 08:00 AM
You could start the car then take the battery cable off. If the car dies you aren't charging.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 12-21-2014, 01:42 PM
This may be of some help. One of the many articles I have collected over the years.
Has proven itself more than once.
Alternator Fault / Flashing Dash Lights
Intermittent dash light indication
Steady simultaneous illumination of more than one dashboard trouble indication lights, i.e. Battery Charging, Steering, and Stop Lamp, indicates one of several possible alternator faults which can be detected by the alternator’s integral electronic diagnostic module.
It would appear that as a safety measure, in the event of an alternator fault those indicator lights which are not illuminated for test purposes at startup, are operated simultaneously.
Flashing dash lights
The flashing of several dashboard indication lights can indicate a rather obscure alternator fault.
The indicator light test circuit which operates at startup, incorporates blocking diodes to eliminate a sneak circuit which would otherwise exist. A fault within the alternator rectifier network, often involving only a single diode, can result in alternating current being induced on line. As a result pulses of reverse voltage, pass the blocking diodes in the circuit which energizes the indicator lights.
Those testing alternators, including professional technicians, can often fail to detect this problem, due to there being only a very small discrepancy in the DC output.
It has been shown that testing battery voltage with a multimeter switched to the alternating current range, will often disclose the presence of the unwanted alternating current, whereas a normal direct current output voltage check will not. An oscilloscope will certainly disclose the problem.
Hope this may be of some use.
File Type: doc Alternator Fault- Flashing Dash Lights.doc (28.0 KB, 235 views)
Old 12-21-2014, 01:51 PM
This is almost always a bad idea.
Maniac Electric Motors has always warned about this from day one.
If you're tempted to test an alternator by disconnecting the negative battery cable, don't do it. A good alternator may indeed keep the engine running, but it is never a good test.
In the pre-computer days, you could pull it off without damaging anything. Today, you risk frying every electrical device in your vehicle. The second you disconnect the battery, the voltage regulator pegs the alternator to put out maximum power. With no battery in the circuit to act as a buffer, the alternator can put out up to 150 volts, depending on engine rpm. When the smoke clears, that “simple test” could end up costing you several thousand dollars for new electronics. Some have been successful, but there is always the risk.
Instead, use a cheap voltmeter. With the engine off, battery voltage should be between 12.5 and 12.8 volts. If it's below that, charge the battery with a battery charger before you conduct the test. Then start the engine and check for increased voltage readings as shown above. If you see higher readings, chances are the alternator is good (more sophisticated testing equipment is needed to detect an open or shorted alternator diode).
Also a warning here.
http://www.troubleshooters.com/dont_...ct_battery.htm
Old 12-21-2014, 02:50 PM
I don't want to start an argument, especially with a well respected guru of the svx, but I disagree.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 12-21-2014, 05:12 PM
I don't want to start an argument, especially with a well respected guru of the SVX, but I disagree.
I do not want to start an argument either, this is just an additional reply to my previous post. There is a possibility that it can be done, but not a guarantee.
I have seen this method do damage on more than one vehicle. To me, the risk outweigh the gains, unless I know the alternator is good. Just adding some facts.
With the battery disconnected, in most instances the alternator voltage
sensing circuit will remain connected, and provided the alternator and its
regulator are working perfectly, and do provide absolutely instant
regulation, damage may not occur.
However, with the battery disconnected and the alternator is FAULTY, as was
suspected, (The very reason for the test being carried out.) damage is very
likely to occur. Faulty rectification or regulation of the output voltage,
can present high voltage spikes on line, or at the worst a constant
over-voltage situation.
With the battery disconnected, even if the alternator is OK, the alternator
can deliver a high-voltage spike BEFORE regulation takes place. There is no
question that such a spike will damage unprotected electronic components.
With the battery connected, the regulator circuitry and included capacitance,
becomes energized immediately when the ignition is turned on, and therefore
is energized and ready to instantly respond to the anticipated alternator output.
Voltage control is therefore normally rendered instantaneously.
Display Modes
