Thread Tools | Display Modes |
AC Cig lighter clock and temp gauge all stopped working at same time today
I let a friend borrow my SVX and he calls me and says all this stuff stopped working this morning at the same time. Climate control totally off, no cigarette plug power, clock and temp gauge. I'm guessing fuse related but seems like all that wouldn't be on one fuse. Any thoughts? Would I check the fuses under the interior panel or would this be the panel that's in the engine? I've never fully understood why two fuse areas...
Thanks for any advice
96 LSi - Hyper Blue, 5 Speed - Magnaflow - Murano take off wheels - 70K |
Re: AC Cig lighter clock and temp gauge all stopped working at same time today
Check the clock fuse under the hood.
Also, unbolt the visors and unplug the wiring. They wires chaff and cause a short. |
Ok that sounds like a good start, will try that. Thanks for quick response. I NEVER touch the visors for these reasons and I bet my friend decided to make use of them.
My bet is on the sun visor wires. They chafe, become brittle and short out against the A-pillar. You can renove the visor and check the wires at the connector for breaks. Either repair them or cut them back and tape them.
The issue is that over time the wires become brittle and eventually lose the plastic covering. When this happens they short out causing you to lose the following functions: Here are the symptoms: A/C lights will light up but NOT provide any functionality Clock does NOT work Sun visor lights will NOT work Mirror adjustment will NOT work Cig lighter will NOT work Rear wiper does NOT work on intermittent setting If you look under the driver side kick panel where the fuse panel is you will see a fuse in the first column 5th row labeled CIG /MIRROR. A 20A fuse Remove this fuse and physically check to see that the fuse has popped.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 04-19-2015 at 09:46 PM. |
Just another day in the life of SVX vehicle ownership...thanks for the tips. I'll plan to post back what the solution was but this sounds like a pretty predictable situation.
Figured out the short. Turns out the visors were fine. It was the cig plug. The metal housing behind the plug internals came undone and it was shorting against the positive.
Thread Tools | |
Display Modes | |
