Old 05-11-2013, 01:38 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
15 minute mod question
Do I just need to jack the car up using the pinch welds on the sides or do I need to use a jacking point inside?
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 05-11-2013, 03:14 PM
Blacky Blacky is online now
Re: 15 minute mod question
I put mine up on ramps. You can probably do it with the car on the ground or with 2 wheels up on a curb for more clearance.
Old 05-11-2013, 06:07 PM
kjoyes kjoyes is offline
I did mine without jacking up the car. I used a jack on the cross member only to lift it take the weight off of it ( I did not jack the car of the ground) , then I took bolts off and install the help! bushings and reinstall the bolts! it made the job easier than it already is.
Old 05-11-2013, 11:57 PM
What is the torque specs for the bolts for this mod?
I looked in the how to section under suspension but can't find the write up.
Car is going back to the shop on monday, they are going to have it on a lift, might as well have them do this too right?
This makes the car handle better? Does it make it ride harder or softer?
What are the chances the shop will break a bolt off or strip something doing this?
Edit, I think I found it. http://www.subaru-svx.net/forum/showthread.php?t=27738
SVXfiles said "94-116 ft/lb, according to our shop computer.". Is this the correct torque?
So that means they can just impact gun it at 100-110ft/lb or whatever it is set at until it is tight?
I just want them to do it right the first time. :P
Display Modes
