Re: engine oil cooler?
water line? The sti oil cooler is not a water/oil cooler, its a air/oil so I just have to use the oil filter adapter and the oil cooler example: http://www.google.ca/imgres?um=1&hl=...r:5,s:27,i:173 thank |
can be a good cooler? or it can do pump cavitation at high rpm? or it not gonna do a big change on the oil pressure or the oem subaru water/oil would be better? Last edited by shark_22; 07-17-2012 at 12:25 PM. |
The water that feeds it comes out of the block and is post thermostat water - so it keeps the oil cool on hot days and warm on cold days. |
