finally done with svx's my black 92 touring is up for grabs
we are purchasing a brand new car in the next few weeks and i am offering my black 92 svx for sale to the forum guys first
Location of the SVX: east orlando fl Year:1992 Model:svx lsl touring VIN: jm1cfx359h106412 Manufacture date: 1992 Paint Color:black on black Interior Color: grey Miles: 86,000 Options: fully loaded power everything AWD or FWD: AWD Modifications: Cross drilled slotted rotors 200.00 HID headlights 150.00 Small car center grill 200.00 Upgraded front and rear speaker with Mb Quarts 400.00 Upgraded 5 channel amplifier 200.00 Upgraded bazooka bass tube 200.00 Upgraded brand new alpine head unit 300.00 Cold air intake system k/n 100.00 Brand new header back magna flow exhaust system “all mandrel bent “ 600.00 White indigo gauges Black carbon wrapped hood/mirrors Upgraded trans cooler $2,300 in aftermarket parts alone ! Major service: Engine maintenance and work done New front tie rod ends and alignment 250.00 2 spanking brand new wheels bearings with proper bearing grease 600.00 New a/c system upgraded a/c system, new compressor/fans/condenser/ with new 134 Timing belt and water pump done by previous owner New valve cover gaskets and cams seals, covers as dry as can be ! done by previous owner New pvc valve Brand new battery from AutoZone 80.00 Engine Condition: very strong Maintenance Records: some available Transmission condition: transmission has the occasional shift flairs from 2nd to 3rd it has not got any better but has not got any worst car is still perfectly drivable and only does it once in a blue moon, the previous owner sad the transmission was replaced Glass condition: perfect, no scratches Type of tire and remaining tread: lots of tread life I would estimate 75% Type of wheels: OEM factory Interior condition: very good shape some wear on driver’s seat typical for the this age of car Body condition: Known defects or problems: Transmission as described above Steering rack inner tie rode is worn out has small play in the driver side wheel but has been this way for a while now, the mechanic said it needs to be replaced and has a small power steering rack leak but its nothing major only a few drops here and there my garage floor is clean Drivers side corner panel has a dent but has been repaired but not very well from the previous owner you cant tell in the pics but it is noticeable up close The speedometer sometimes doesn’t work when the prevouis owner replaced the gauges with white gauges there must be a loose connection some where a swift tap on the dash and they start working, Comments about the car: this is a great car with low miles and tasteful mods, Car still has lots of life in it and would be great for any collector Asking price: make offers I paid $4,500.00 for the car back in November I still have the receipt I put in the new tie rod ends and alignment at $250.0 2 new rear wheel bearings $600.00 New battery with warranty 60.00 New pcv valve 10.00 Completely re-did a botched exhaust system with a nice mandrell bent magna flow system 600.00 I have all the receipts if you would like a copy I have a total of $6,000 into this car with all receipts to provide I would consider a lower price without the killer sound system also, previous owner has about a $1,000.00 worth of audio gear in it, the svx it sounds awesome ! car has always been garaged its entire life ! the paint is amazing not a single fade mark anywhere !
2008 evo x with sss package 430 hp 380 torque stock turbo with basic bolt ons 12.56 @ 109 fully weighted 3,500 lbs |
Re: finally done with svx's my black 92 touring is up for grabs
guy i will have pics taken this weekend i am having it profesionaly detailed and shampoo'd
this is the only pics i have for now http://i1212.photobucket.com/albums/...7/IMG_4386.jpg http://i791.photobucket.com/albums/y...X/CIMG0018.jpg fog lights no longer there
Your VIN appears to be incorrect and has only 16 numbers
JFICX3538NH106412 .
jf1cx359nh106412 sorry forgot the N
Wow after all,u went through through to get one I thought you would have hung on to it a little longer. NICE clean car, good luck with the sale.
i will have nice pics for every one on monday ,
here are the pics just finished having it detailed
i have more if you like this one shows where the repair was done !
air scoop feeds intake tiny bit of paint bubble some paint flake on the bottom part of passanger side door, very clean engine bay
Lovely! GLWS
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram |
florida car info
Vehicle: 1992 Subaru SVX (JF1CX3539NH106412) Event date Location Odometer reading Data Source Details 05/12/1994 FL 20,000 State Agency PASSED EMISSION INSPECTION 06/13/1995 FL 26,000 State Agency PASSED EMISSION INSPECTION 02/21/1996 FL 29,000 State Agency PASSED EMISSION INSPECTION 02/23/1996 FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 05/30/1996 FL 31,101 Motor Vehicle Dept. ODOMETER READING FROM DMV 07/29/1996 FL Motor Vehicle Dept. TITLE (Title #:63506377) (Leased Vehicle) (Lien Reported) 07/29/1996 SAINT PETERSBURG, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL (Leased Vehicle) 07/29/1996 FL Motor Vehicle Dept. FLEET 08/01/1996 SAINT PETERSBURG, FL Motor Vehicle Dept. TITLE (Title #:0063506377) (Leased Vehicle) 06/12/1997 FL 34,000 State Agency PASSED EMISSION INSPECTION 06/13/1997 SAINT PETERSBURG, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 06/30/1998 SAINT PETERSBURG, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 07/06/1999 SAINT PETERSBURG, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 07/28/1999 SAINT PETERSBURG, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 06/13/2000 FL 55,000 State Agency PASSED EMISSION INSPECTION 06/28/2000 SAINT PETERSBURG, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 06/06/2001 SAINT PETERSBURG, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 06/04/2002 SAINT PETERSBURG, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 05/22/2003 SAINT PETERSBURG, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 06/18/2004 SAINT PETERSBURG, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 08/22/2004 FL 58,914 Motor Vehicle Dept. ODOMETER READING FROM DMV 09/27/2004 LARGO, FL Motor Vehicle Dept. TITLE (Title #:0063506377) 09/27/2004 LARGO, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 11/03/2005 LARGO, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 11/15/2006 LARGO, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 10/29/2007 LARGO, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL 07/21/2008 TAMPA, FL Motor Vehicle Dept. TITLE (Title #:0063506377) 07/21/2008 TAMPA, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL EXCLUDED/EXEMPT 01/09/2009 TAMPA, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL EXCLUDED/EXEMPT 12/30/2009 TAMPA, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL EXCLUDED/EXEMPT 01/03/2011 TAMPA, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL EXCLUDED/EXEMPT 09/28/2011 TAMPA, FL Motor Vehicle Dept. TITLE (Title #:0063506377) (Lien Reported) EXCLUDED/EXEMPT 12/11/2011 ORLANDO, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL EXCLUDED/EXEMPT 12/15/2011 ORLANDO, FL Motor Vehicle Dept. TITLE (Title #:0063506377) EXCLUDED/EXEMPT 02/10/2012 ORLANDO, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL EXCLUDED/EXEMPT
hey guys the ebay auction ended with dissapointment, $2,600.00 was the highest bidder and no way will i sell it for that, i would strip it and send to the junk yard for more then that,
the reserve on the car was $4,500 as it sits with everything in it. i am lowering the price to $4,200.00 as it sits you also have the option to buy it without the sterio equipment for $3,700.00 the bazooka tube, head unit, amplifier, and maybe the mb qaurt componets will be pulled for that price, i do have the factory headunit for you to install $3,700.00 gets you a lot of car i am taking a true loss on the car i have $6,000.00 tied up in this from november till now i have $1,200 in recipts alone for the new exhaust system and wheel bearing replaced 3 months ago, plus new battery and tie rod ends,
good luck with the sale. maybe if you tossed up an exhaust clip it would get more attention?
http://www.youtube.com/watch?v=D5WBk...ature=youtu.be
as and your shall recieve, the things i do to sell a car ! LOL its not that great but you get the idea, this was this morning http://www.youtube.com/watch?v=MervfMbqXlI inside the car the exhaust is verry mellow it has precats, resonators and mufflers all done with magna flow
