"stop lamp" light
All of brake lights are working but on the dash the "Stop light" continues to go on once I hit the brakes. Any ideas
Re: "stop lamp" light
Have you replaced a burned-out tail light recently? The stop lamp checker uses the amperage difference between the trunk panel and the two body-mounted stop lights to determine if a bulb is bad. Very similar design to a GFCI outlet in your house. If you have unmatched wattage bulbs, the difference in amperage can be enough to trigger the checker even if all four bulbs work. Bulbs are dirt cheap so when I have one go out, I replace all four with the same brand. This is the easiest place to start. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Could be low on brake fluid also
Not likely. The "STOP LAMP" bulb in the dash indicates a problem with the lighting circuit only. The "BRAKE" indicator light usually means low on brake fluid. .
OK confused as to what light he was talking about . Then I stand corrected . NEVER MIND
The misinformation you've been posting lately with complete confidence is becoming insane!
If I recall correctly, the "BRAKE" light will come on if the brake fluid is low. However, the "STOP LAMP" light is a quite different animal and is not related to the fluid level in the slightest.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
![]() Harvey.
So no, there's no way it could be what he thinks it could be.
I would not jump on someone for offering an explanation, everyone has to learn. ![]() Harvey.
It is true, though, that not being sure is a good reason for not typing when it comes to technical information. We have enough veterans here to speak!
![]() Harvey.
Please don't squabble. This forum is a place for being open and honest. There is no need to be negative. We all have something in common - we love the SVX.
There is enough negativity in the world. Mike
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com |
Sheesh.
Thread Tools | |
Display Modes | |
