Old 11-04-2002, 01:23 PM
Alcyone SVX LSL
Question ATF filter
Ok i am getting my tranny fluid changed soon and i was wondering what kind of ATF filter the car has and how much i should be charged for it.
-thanx in advance!
Old 11-04-2002, 01:47 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: ATF filter
-thanx in advance!
Not sure about the filter in the pan, but the "program" kit for the 92's (which will work on all SVXes) is about 10 bucks, including hoses and hardware.
Randy Johnson
Mike Davis -- at Reading VI
Old 11-04-2002, 02:55 PM
gcookaustin
I replaced the internal filter in the pan, and I believe it was about 30. Check subaruparts.com
Old 11-04-2002, 05:01 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
I check out the internal filter at Pep Boys - about $30, if I remember correctly.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 11-04-2002, 05:58 PM
SVX ROO SVX ROO is offline
ATF fluid flush!`
Leslie
I strongly suggest that you do not just have fluid changed. Instead you have the complete flush. A fluid change only changes 25% of fluid. The flush system consists of adding a solvent to remove deposits, circulation hot through all of the gear changes (they do it with car on a lift) and then they push ALL the old fluid out and push in new. This is done with an external circulation cart where they can monitor the fluid.
I had my '94 done at 125k miles. It previously had the simple change done per routine maintenance. The fluid they removed looked like sludge!! They had to do two total fluid changes to get it really clean.
This service costs $110-135, including the new fluid, for one flush.
A recommendation from me. Others please comment on this service.
Ken
Old 11-05-2002, 05:23 AM
svx_commuter's Avatar
Re: Re: ATF filter
That is actually the filter for a legacy that fits just fine. It is the same filter but different hoses and bracket. I just bought 4 of them kits as I could not get a replacement Legacy filter or SVX filter for less than $50.
Old 11-05-2002, 07:18 AM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
I strongly suggest against a flush. Small particles in the ATF from years of non-drain/filling actually act as seals. If you flush it you run the risk of knocking out this sealing material and causing major AT Damage. Just do a series of Drain/fills and over time you will have replaced all the fluid.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 11-05-2002, 10:13 AM
CigarJohnny's Avatar
CigarJohnny CigarJohnny is offline
Send a message via Skype™ to CigarJohnny
Question Re: Re: ATF filter
Randy, could you kindly educate me on this "program" kit? What exactly is it? What kind of hardware is included? Is it for internal or external filtration?
Thanks in advance!
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX)
Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting.
Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well.
You can tell the lack of craftsmanship by the wrinkles in the duct tape.
Old 11-05-2002, 10:24 AM
Aredubjay's Avatar
Re: Re: Re: ATF filter
Thanks in advance!
As a "band aid" for the 92's tranny problems, Subaru developed an external filter. It filters the fluid on the inlet side of the stock cooler to try to keep the screen in the stock cooler from clogging. Many are using this program kit on their cars as "cheap insurance" against impurities. The hardware involved is merely a bracket (that fits onto the bottom of the radiator at the radiator bracket) and hose clamps. The hoses are inclluded, so, alls you have to do is figure inlet/outlet and hook it up accordingly.
Randy Johnson
Old 11-05-2002, 05:59 PM
Earthworm's Avatar
Meow!
I can't vouch for or against the tranny flush but I will strongly encourage you to have the external filter as well as the screen filter in the tranny both replaced. Although the internal filter may LOOK clean it isn't. Has anyone else taken a look inside their old screen filter after changing it?
Old 11-05-2002, 06:16 PM
FYI
I have some pictures in my locker that show the program filter (OEM) and another that I replaced it with. Look under tranny filter.
Display Modes
