#76
Re: NO MORE CLICK click CLICK START..ONLY START! starter relay
![]() Keith ![]() |
#77
I've never "fixed" mine. The "bandaid" has been working for me for over 7 years now.
#78
I want to sincerely thank the folks that did all the research before me. My '92 Pearlie has had this intermittent issue for the past year; it first manifested itself last July in a little Texas town on a Sunday. Fortunately, it started after a few clicks. The 'click, click, click' became more frequent over the past year and research led me to this posting.
I found the Auto Zone relay without a hitch, although they say it's an A/C relay in their computer. The only 'down-side' to the whole operation is my 64 year old body doesn't contort to access the under dash area like it did when I was 25. Thanks again, Roy in AZ |
#79
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
#80
Mine is always caused by low battery voltage, it clicks I check, its below 12, I charge she starts, although probly one day it will not, cheers all...................G
I thimk ther4 I an, what? huh! ![]() 03 Baja. 05 Baja turbo 92legacywagon"snow" 94legacywagon"whinny" 84Brat"huey" 92svx"samantha".pearl 92svx"sabastian"4.44 ![]() 92svx"sabrina".ebony 05legacy gt limited "Moon" blue. 06 Subaru legacy gt limited. |
#81
Got the click in my project car. Didn't click before the swap. Decided to apply the band-aid fix again since it worked perfectly the last time.
#82
Well... It seems as though the relay didn't fix my particular problem. I finally was able to have the 'Click, click, click' issue manifest itself when the hood was open and my trusty mechanic standing in front of the car. I appear to have a starter solenoid issue.
#83
http://svxworldforums.com/forum3/3422.html Harvey.
#84
So after ordering 4 starters from different venders none seeming to be the right part. Noob mistake, turns out I needed one for an 04 WRX. Got her all fixed and now my rear bearing seems to be going out.
#85
Where do I look next after replacing the relay and the starter switch? I have a test light hooked up to the wire going to the starter, and I'm not getting anything...
If the key is turned to run, and a jump a wire from batt + to the starter, it starts right up, so it is somewhere between the key and the starter. What else is there beside the relay and the ignition switch?
Dave - 03 Baja - 92 SVX - 86 Brat - 08 OB 3.0 Last edited by Hocrest; 04-12-2012 at 08:51 PM. |
#86
neutral safety switch
#87
If you are getting nothing, check the wiring at the gearbox inhibitor switch. Try it in Netural, the Park contacts may be burnt. If you are getting something, you may be best to do the Bosch relay mod. to prevent all that current from burning up all the switches. Have a look here for how to do it. http://svxworldforums.com/view_post.php?post_id=35308 Harvey.
#88
I was thinking earlier tonight that I want to jump the pins on the trans harness like we do for MT swaps tomorrow and see if that the issue. Does anyone know where the shift indicator falls in the sequence between the key and the starter?? I'll also have my SVX here tomorrow, so I can pin out the wires step by step and compare.
#89
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
#90
It is the small wire to the solenoid that has nothng? The sequence is, the key, security relay, Inhibitor switch on the box, starter solenoid. Don't forget to try it in N, it case the P has a problem. Harvey.
Thread Tools | |
Display Modes | |
