Go Back   The Subaru SVX World Network > Regional SVX Forum & Clubs > European Forum
Old 02-16-2011, 03:24 PM
oab_au oab_au is offline
Re: Price for a new gearbox
Originally Posted by SVXdk View Post
The seller has two gearboxes - "early and late types". I suppose, they are the two boxes mentioned on his list, TZ102YP1BA (or CA?) and TZ102YP1YC.
Our chassis number is JF1CXWLE0RG005075. Can any of you confirm, that one of the boxes will fit on our SVX?
Thomas
Thomas as far as I know the 95 was the last of the box modifications, carried out. The only difference that would cause concern is that the C solenoid was changed on the 95 model on.
The 94 TZ102YP1BA has the normally open valve and the 95 TZ102YP1CA has the normally closed valve.
As the TCU needs to match the box, yours is a 94 model, the TCU will need to use the earlier TZ102YP1BA box.
One Arm Bloke.
Tell it like it is!
Old 02-17-2011, 06:00 AM
blueji's Avatar
blueji blueji is offline
Harvey, still gear box related question.....checking your link for the QC, Budfreak states 'no longer available' what's the score?
John
______________________________
the older I get, the faster I was
Old 02-18-2011, 09:25 AM
SVXdk's Avatar
SVXdk SVXdk is offline
Thumbs up Re: Price for a new gearbox
If you are looking for the gearbox John (blueji) linked to on e-bay you will not find it. The reason is we bought it :-) Thanks alot for all your help
Today I have arrange for a carrier to pick it up, they will deliver it to the workshop where our car is. Hopefully we should be running again quite soon. We will let you know when the car is back on the road.
Pernille
Old 02-18-2011, 11:19 AM
blueji's Avatar
Pernille
It was the link in Harvesy's reply about the 'Quick Change' I was refering to.....
Glad I was able to be helpful with spotting the box, hope you get your car sorrted!
John
Old 02-18-2011, 03:17 PM
stevek stevek is offline
Just a thought, it took over 6 oil changes to clean the system after a high speed clutch failure on mine. Are you sure the place that worked on the car before made sure all the crap was out?
With hindsight I should have changed the rad but so far no probs. Luckily I have a pal who has access to free ATF....
Rate This Thread:
