Old 01-26-2011, 07:16 PM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Binding again – sung to the tune of “Drinking Again”
Yes… Replaced Duty Solenoid C. Car worked great for a day then it started binding and I got the blinking Power light at startup again. Checked the code and it was “24”.
Is my TCU bad? Is there something else that could be affecting it? I read in some older posts about the “wire” that connects the TCU to the solenoid.
Any thoughts would be appreciated.
Paul
1992 LSl (Black Mica)
1965 Mustang G.T. Fastback
1990 Mustang G.T. Convertible
1986 1/2 Nissan 4x4
2004 Vovlo XC70 (wife's)
Wonderful Wife
Wonderful Son
2 Cats
Incredibly blessed!
Old 01-26-2011, 09:38 PM
oab_au oab_au is offline
Re: Binding again – sung to the tune of “Drinking Again”
One day isn't bad.
It looks like there is a wiring problem, between the TCU and the solenoid. Check all the plugs on the way down. The code looks at shorting or open circuits, as the solenoid is new, it should be ok, unless its plug in the box is jammed or pulled open.
One Arm Bloke.
Tell it like it is!
Old 02-08-2011, 08:18 PM
SVX JAZZ's Avatar
Tired
I've been driving it a while after I checked the wiring. It works part of the time. Its almost as if it has to "warm up".
Last week it worked all day but then the next it was back to binding. I can't figure out a pattern.
Paul
1986 1/2 Nissan 4x4
Wonderful Wife
Wonderful Son
2 Cats
Incredibly blessed!
Old 02-08-2011, 08:45 PM
Cam Cam is offline
I would say the wiring is suspect, as Harvey suggested. In my experience most intermittent faults are electrical.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Display Modes
