backfires and hot driver's cat
So my 92 has decided that I need something to fix again... I'm just trying to pinpoint exactly what's wrong here being i'm stuck out of state visiting family. Here's what I have:
-the engine idles a bit rough, the exhaust comes out in bursts like there's a misfire,and makes backfire sounds, but the engine itself runs smoother at idle than i've seen with a dead miss -the engine bogs out with any swing in rpm, up to about 2500, where it decides to suddenly get off the couch and run more or less correctly -the driver's side pre cat glows after a while i've been doing some reading and see it is most likely a stuck open injector, or the engine jumped time on that one side. is there anything else i should check, or anything with those very specific symptoms I should investigate?
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
Re: backfires and hot driver's cat
Fouling plug on the left side, or coil arcing are the first things that come to mind for me.
Both are relatively easy to check, if you got the patience.
The Worm ![]() _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
My vote is for timing belt jumping one (or more) teeth.
A compression test would give you the results in a hurry.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
Check your spark plugs on that side, and see if its limited to one cylinder or all 3. That will give you a clue as to what to test next.
