Old 06-16-2010, 10:02 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: stage oem or stage 2 clutch?
I've never even driven a manual car before but I would only use a stage 2 if I were doing a conversion
Old 06-16-2010, 04:04 PM
Originally Posted by Tim View Post
I had the F1 racing Stage 1. I ended up selling it because of all the horror stories with cheaper clutches. I feared I would have had to do it again and it would have cost me more in the end. Definitely try to hold out and save for the better clutch if you can.
This what I have, too. I would not say it is horrible, but you do get what you pay for. Slight slippage, slight stickage. I was paying attention yesterday and I do get that jerkiness in 1st, 2nd, and 3rd.
I wouldn't recommend it, but for someone on a budget I would not not recommend it.
Old 06-17-2010, 05:54 AM
Gamesy's Avatar
Gamesy Gamesy is offline
after much thought i'm gonna go with Exedy Stage 2
Old 06-17-2010, 12:50 PM
Gamesy's Avatar
scratch that after much readin on NASIOC and talking to another who got stage 2, going stage 1 exedy or ACT, apparently stage 2 chatters and wears out quickly
Old 06-17-2010, 12:52 PM
Wikedjuggalo's Avatar
Rebuilding
Please don't listen to the 5spd svxers here :P... but seriously spec is a great clutch in my opinion. I went through the same thing when determining which clutch to get with my swap. I asked around and found the census was SPEC stage 2. Sure its pricey but its worth it.
Old 06-18-2010, 09:25 PM
RoughSilver92 RoughSilver92 is offline
I don't know which tranny you have or what mods the car recieving the swap has, but I can say that if the KSB04 oem replacement from exedy fits (newer non-wrx) it is all the clutch a stock svx needs. Mine has been driven daily for over a year now and is still holding strong, just gave a a thorough "testing" a few hours ago
Old 06-19-2010, 06:34 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I've got about 3 years and 20k on my trans and clutch (including me learning how to drive stick on it). It has held up with no problem
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-19-2010, 08:12 AM
Gamesy's Avatar
running oem?
Old 06-19-2010, 08:15 AM
Tim's Avatar
Tim Tim is offline
Spec stage 2 for an impreza 2.5
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-13-2010, 05:26 PM
Coming back to this thread to say that I now assertively do not endorse this clutch. It has begun rattling and chattering at low RPMs like some kind of wind-up joke teeth.
Still drives fine, though.
Actually while trying to make the chattering stop I found out that the car is capable of moving from a stop in 3rd and 4th gears (my idle was a bit high).
edit:
5th gear, too.
Old 11-14-2010, 05:08 PM
Nevin's Avatar
Nevin Nevin is offline
This is on my Mazda, but I have a SPEC stage 2+ and I really like it. It's a full face, so it doesn't chatter like a 6-puck, and its very driveable everyday. It is rated at 400 lb./ft. of torque, and I'm maybe running 340 lb./ft through it. Works very nicely for me.
What some old hot rodders (as well as other new folks) did was to use an OEM pressure plate, and an aftermarket disc. This would give smoothe engagement but a higher torque holding than the stock unit because of the better friction disc of the aftermarket unit.
Some of the probe guys are doing this too because the probe trannies are notoriously weak. Less shock loading means less stripped gears.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 11-19-2010, 10:12 AM
Naru's Avatar
Naru Naru is offline
oh s**t ...
i have a f1 one...
ok, i think about buy a new one.
anyone have good dealer for a good streetable clutch?
thanks!
Display Modes
