Re: Slippage between 1st and 2nd gear
Ok, sounds easy enough. And if it is low-line pressure. what would the fix be?
94 SVX LSI 2001 LegacyGT (daughter's ride now) 2005 Legacy outback XT (wife's car) all stock and likely staying that way for now 1981 Datsun 280zxturbo summer toy |
Ok, I fear it is the latter, but we will see....
It has been made clear that something is slipping and this can be surely be relied on as a being well founded.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 04-27-2010 at 07:46 PM. Reason: Addition. |
Verify by properly test the line pressure, using a gauge connected to the port provided for this purpose. Any reliable transmission shop should be able to carry out this standard test. First things first and which do not require removal of the transmission. Blocked external cooler or filter. Blocked main strainer. Solenoid "A" valve fault. Blocked internal strainer/filter associated with the pilot valve. This calls for removal and separation of the valve body.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
You said your fluid was good as far as level but how old is it? If you have a lot of miles, contaminated fluid, and/or overheated your fluid this could possibly affect your line pressures as well, something to do definitely when or if you take Trevors advice on the trans filter. Though if you drain it may as well drop the pan to inspect further.
Fluid was clean (replaced about 11/2 years ago) but i did replace the fluid again today just to see if it makes a difference. Seems to have made no difference. Did not drop the pan but it will be the next job I get done after checking the pressure. Will let everyone know the outcome.
Ok just thinking: if the tranny is toast, how long or how many kms. could I put on it living with this slipping between 1st and 2nd before it gets undrivable. Right now it's really no problem. Drives perfectly once it gets into 2nd. And I don't drive the car much as it is....
Anyone living with this problem....
That'd be me. I've been driving her for about six months or more like this, no real complications. I've learned when to press for gas and when to let off. I'm going to get my brake band adjusted when I get my exhaust work done by OT though.
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k ![]() |
ok well that is interesting considering I'm probably taking the car off the road for six months to drive my Z for the summer. hmmm I could put off this major repair for at least a year or two....
unplugged the line pressure module (behind the battery) Seemed to make no difference whatsoever.
Freeman: Is it your daily driver and how many miles do you put on a week???
#28
Yes it's my dd and I drive it to and from work 5 or 6 days a week plus I drive around for fun. No clue how many miles.
#29
[QUOTE=Subie59;644934]ok well that is interesting considering I'm probably taking the car off the road for six months to drive my Z for the summer. hmmm I could put off this major repair for at least a year or two....
unplugged the line pressure module (behind the battery) Seemed to make no difference whatsoever.[/QUOTE] When you say "no difference whatsoever" Do you mean, the problem of shifting was the same? Was there no difference in the hardness of the shift, with the resistor unplugged? Harvey.
#30
[QUOTE=oab_au;644967]
