Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Turbo Projects
  #76
Old 03-28-2010, 07:06 PM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Re: STeeL's built motor/turbo build
Loaded the WRX trans in my car to drop off tomorrow, I have no idea what the rebuild is going to cost me but I'm optimistic since I'm providing the parts and they wont have to remove or reinstall, just labor.
Got on Subaruparts.com and ordered the last of my OEM parts. Two parts left to buy on my list =) ...Although I'm not looking forward to the clutch..
Old 03-28-2010, 07:29 PM
mbtoloczko's Avatar
sans SVX
Are you getting a Hydra Nemesis for engine control?
Mychailo
Visit my locker
Old 03-29-2010, 12:32 PM
I would prefer to get on my hands and knees and beg Tom to let me mail him the new plug and play MegaSquirt that fits our stock connector and see what he can do with it. Not only cause its cheaper but because I don't know anyone within a few hundred miles of me thats a Hydra tuner.
Old 03-29-2010, 02:19 PM
mbtoloczko's Avatar
sans SVX
I thought the Hydra included software to allow you to tune it yourself like an AEM EMS.
Mychailo
Visit my locker
Old 03-29-2010, 04:34 PM
It does... most people wouldn't know where to start with tuning in general though so as a precaution I have recomended they get it tuned by a professional... I don't lock my maps, so they could use the map I give them as a starting point
Old 03-29-2010, 05:41 PM
mbtoloczko's Avatar
sans SVX
ok, I guess the lack of tuning skill does make sense for the SVX community. Great that you don't lock your maps. Do you have the MegaSquirt adapted to the SVX and have a set of base maps for it?
Mychailo
Visit my locker
Old 03-29-2010, 05:43 PM
nope. offered to try for someone but they never sent the unit
Old 03-29-2010, 05:49 PM
mbtoloczko's Avatar
sans SVX
I imagine that adapting a Megasquirt would be a fair bit of work because you'd have to figure out the sensor calibrations. I imagine you'd set it up as speed density (is there even a MAF option with MS?). Did you happen to obtain or measure the sensor response info when you were working with Hydra?
Mychailo
Visit my locker
Old 03-29-2010, 05:51 PM
what response info are you looking for...
It won't be too bad setting up the MS w/ the position sensors... Just run a std 24 tooth wheel setup with an aux trigger for cam position.
Old 03-29-2010, 06:10 PM
mbtoloczko's Avatar
sans SVX
Thought you might try to use all the OEM sensors, but sounds like you'd just go with all the aftermarket sensors that people typically use with the MS.
Mychailo
Visit my locker
Old 03-29-2010, 06:15 PM
No, use the stock sensors... Just adjusting the trigger type
Old 03-29-2010, 06:30 PM
mbtoloczko's Avatar
sans SVX
ok, maybe not as bad as I though. If you go SD, then I imagine you'd use a GM 3 bar and a GM IAT sensor for SD duties, and those calibrations are readily available. You've got cam and crank figured out. NB O2 are all the same, so nothing to worry about there. That leaves the resistance vs temp curve for the OEM coolant temp sensor, and I suppose you'd have to figure out the idle air control valve response characteristics. Would you try to control the plenum separation valve? Have you looked at whether the MS can fire the factory ignition system? And of course it would be great to work out knock sensing if the MS supports it.
Mychailo
Visit my locker
Old 03-29-2010, 06:59 PM
with enough work it can be done... No one is going to do it for free, which means it will likely not be wanted... That was the point of using the Hydra Nemesis... Plug-n-play w/ base maps... People don't realize what they are getting when they buy
Old 03-29-2010, 07:41 PM
mbtoloczko's Avatar
sans SVX
Strongly agree with that statement. Don't think that people realize that while the MS is a good price, the effort required to adapt it is much higher.
Mychailo
Visit my locker
Old 04-01-2010, 04:46 AM
Everything was going smoothly until Jesse said to me, "Do you have a 12 point deep well 1/2 inch?" ... Damn ARPs... Finally found one at our FIFTH stop (If you don't have one, don't waste your time looking... Go straight to Sears).
So we'll try again Monday. I'm going to order my timing belt today and hope I can get it by then so we can set the timing, after that I can finish it on my own. I'll be putting on the water pump and cross over pipe in the mean time.
Rate This Thread:
