Re: Quick Change Shift Kit Question
The cutting of the engine torque during the change not only produces the ‘do nothing’ between gears, it robs us of the Torque converters action that should happen on the change. By cutting the engine torque the converter can only act as a soft coupling between the engine and box, the gear ratio changes and the engine has to pull that higher ratio, that can bog it down, eg 1st gears 2.78 to 2nd gears 1.54.
With the torque cut removed, the converter is allowed to handle the full engine’s torque, it will act as a variable gear ratio between the engine and the gearbox that can change the ratio from 1:1 down to 1.9:1. So that when the change is made from 1st to 2nd, instead of the 2nd gears ratio of 1.54, the converter can reduce this to 1.9 X 1.54, to 2.85 then as the converter brings the engine speed down to the lower gear, the converter will reduce this to 1.54. Because the converter reduces the gearing, it also multiplies the torque to give that surge on the change, that only a Quick Change driver can enjoy. Harvey.
"You can't believe everything you read on the internet; that's how World War 1 got started." |
Increasing the base line, line pressure will mean that the pressure applied to the B and C solenoids will also be higher that can cause lock-up clutch drag, and transfer clutch binding. Harvey.
For some reason I thought it was only on the 3-4. Hm, I can't remember everything but I don't know. I don't see it hurting transmissions is all. I'd put it on my car, but by 1-2 shift is already so hard it squeeks the mounts
Obviously if the calibration is adjusted and the overall pressure raised, the “lowered” pressure must also be raised. Quote:
By contrast, the very reason for including torque reduction feature, is made clear.
Take it this way if you try to stop something spinning, if you hold light pressure it takes longer to stop, but if you apply hard pressure it takes considerably less time to stop. |
In point of fact, your reference to the different models proves the need for the features incorporated in the SVX transmission. Not by contrast, that the features are superfluous. The SVX is a much heavier car than the models to which reference has been made, and also includes a higher final drive ratio. Comparison on the grounds suggested is in no way valid and is in fact stupid.
It would appear that you are thinking of the power involved in closing and holding the friction surfaces in secure contact. The torque referred to is that which must be transferred by the clutches. The more torque having to be transferred when a clutch closes, the greater the wear. Reducing this torque during gear shifts, therefore has a very real advantage.
You are much more intelligent than to bring final drive ratio in as a factor. Weight difference is negligible considering cargo and passengers or lack thereof.
#28
Increased pressure results in less slip for the same amount of torque (as you correctly said). But increased torque results in more slip for the same amount of pressure. What Harvey does is increase both torque and pressure but not necessarily by the same amount. So it's hard to say whether there is more or less slip during the very short time period of the gear change.
#29
A study of the relationship between RPM, torque and power, will provide an understanding of what is involved. It is also necessary to be conversant with the terms, net and gross, in respect of weight. Only then can one consider and be aware of the parameters overall, as were presented to the designers of the SVX.
#30
Let it be very clear that when a “QC” is fitted, immediately after more than one third throttle is applied, regardless of any other function, all control of transmission line pressure via the TCU ceases; i.e. the operative signals from the TCU are locked out and maximum line pressure prevails.
What is more, the “QC’ does not in any way act progressively, as has been claimed. The action is complete and immediate. As soon as a set degree of throttle opening has been applied, from that point on, the operative signals from the TCU are immediately, completely locked out, resulting in continuous uncontrolled, maximum line pressure.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 03-26-2010 at 03:52 PM. Reason: Typo |
