Problem
I don't know how long it's been like this but my drivers side car door unlocks just by turning it. Even with another key or a screwdriver.. what can I do?
Re: Problem
Install a new lock cylinder.
If you have a keyfob it shouldnt be too much of a problem to have a different key for the driver door. |
Re: Problem
you can even have a locksmith rekey the tumblers to match your existing key.
Re: Problem
Hm alright, thanks.
Re: Problem
Keep that info secret, If no one else knows no prob. I have a wagon that the key broke off in the door just left it and use the broken key...........G
I thimk ther4 I an, what? huh! 03 Baja. 05 Baja turbo 92legacywagon"snow" 94legacywagon"whinny" 84Brat"huey" 92svx"samantha".pearl 92svx"sabastian"4.44 silver 92svx"sabrina".ebony 05legacy gt limited "Moon" blue. 06 Subaru legacy gt limited. |
Re: Problem
I was thinking similar to gbianchi ... like shhhh if no one knows then it isn't a problem.
I have one SVX where one key does all and then I have another SVX that requires 3 keys. The one I am fixing up is the one with 3 keys so I am contemplating stealing the locking cylinders and ignition from the car that matches the single key. Extra work and a PITA but probably worth it in the end. You will have to remove your interior door panel to gain access to the lock cylinder and then you can get it worked on or replaced (your call, your $$). While you have your door panel off though would be a great time to do some sound deadening and replace that old plastic inside the door with Dynomat or similar product. |
Thread Tools | |
Display Modes | |
