Old 02-17-2010, 06:13 AM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Re: 1992 LS-L parts car
Originally Posted by redlightningsvx View Post
How good is the door glass(lower)? Any scratches in them?
I will find out today for you. I have t pull the drivers side out regardless to get to one of the tracks for another member
Old 02-17-2010, 10:23 AM
Boxersix's Avatar
I checked those windows and they do have some light vertical scratches in them, presumably form dirt in the felt guide pads. sorry.
anyone else?
Old 02-17-2010, 11:41 AM
Cam Cam is offline
Right side door sill. It covers the seam of the carpet along the passenger door.
I can PM you with an offer if you would like.
Thank you very much
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 02-17-2010, 02:23 PM
Boxersix's Avatar
Thank you very much
I have to see if it's still there. Will check tomorrow morning.
Old 02-17-2010, 05:37 PM
Boxersix's Avatar
Made a master list, see first post.
Old 02-18-2010, 05:07 AM
CorSVXette's Avatar
CorSVXette CorSVXette is offline
SVX- My daily driving Corvette
Send a message via AIM to CorSVXette
Classic SVX
Hi
I need the driver's side Sill Plate? If that is what you call it. It is the plastic piece under the door. It needs to be gray with all the tabs. If you have the metal clips and the white plastic pieces that go into the body that would also be great.
Thanks,
Paul.
Paul
1969 Corvette
1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS!
1995 Corolla
2003 Highlander
Old 02-21-2010, 08:00 PM
unsie unsie is offline
Hi I'm looking for the interior rear view mirror and the drivers door window switch cluster. Can you help? Cheers
Old 02-22-2010, 06:42 AM
Boxersix's Avatar
I have both of those, make me an offer for them, shipping will be about ~$8.
Old 02-22-2010, 06:43 AM
Boxersix's Avatar
guys asking about the sill plates....i checked and both are damaged pretty bad. Cracked and/or missing mounts tabs on the bottom. Sorry.
Old 02-22-2010, 06:46 AM
How does the radiator look?
Old 02-22-2010, 07:27 AM
crash_2365 crash_2365 is offline
Windshield and master window switch?
Old 02-23-2010, 05:31 AM
CorSVXette's Avatar
Classic SVX
Thanks for checking.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 02-23-2010, 08:12 PM
Boxersix's Avatar
Not bad, held coolant without a problem. I can remove the fans and inspect better tomorrow for you.
Old 02-23-2010, 08:14 PM
Boxersix's Avatar
Both are available. Windshield is a blue tint variant(blue sunstrip)
Rate This Thread:
