11:1 Engine Rebuild
Hi everyone, I am currently tearing down my motor, and am having my machine guy resurface the heads, port and polish, rework the crank, and bore the cylinders out to fit my new 11:1 comp. ratio pistons from ECUtune
![]() I am also replacing all the stuff that could possibly fail on me, i.e. water pump, oil pump, valve gear, all the seals, vacuum lines (thinking of going with blue silicone), etc. When i have her back in the car I will post pictures. However, this is my first engine rebuild, and I am not so well educated on the boxer design except for what I have noticed during my teardown. Any tips on things that should be replaced, or things that should be checked would be greatly appreciated. Well, thats all for now, updates to come. Thanks all. Cameron |
Re: 11:1 Engine Rebuild
Find out if the valves are going to be an interference fit or not with the new pistons. - Ed
First off, thank you for the suggestion. I do not claim to be some mechanical genius or a schooled automotive tech. I simply have a decent understanding of the EG33 and want as much out of my SVX as possible without taking her off the street or too expensive to drive around.
Michael Emery at ECUtune says that the pistons, cams, and stock valve-gear are all matched up and are zero-interference. That being said, I am hoping that the stock valve gear does not prove too weak. Does anyone think that an upgraded flywheel or larger torque converter would be necessary? my flywheel does not appear to be cracked or warped, but I saw some that Tom had and they looked pretty beefy. |
probably wouldn't hurt to go with the heavier flex plate that yt had in a post a while back (flywheels only come with manual transmissions...
![]() Good luck with your build! Make sure to post up pics of your progress ![]() -Bill
I suppose thats an important little bit of info
![]() Any slick ways to seperate the block? I am still working on the circlips ![]() |
Subaru Part #12332AA071 This is the Phase II flex plate that is a direct bolt up for our engines and our Phase I transmissions... According to YT's micrometer, the old style plates are 2.05mm thick The new style plates are 3.25mm thick. ![]() .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Also get some Cometic headgaskets
circlips
I am getting pretty frustrated, and am wondering about an alternate route to break down my cylinder block further. so heres my question...
Can i seperate the block with the pistons connected to the rods and wrist pins? I dont think i would have any problems from looking at it, but it would be nice if someone could confirm that this would work. I would want to seperate the block and carefully slide the pistons out of the cylinders with the entire crank assembly still assembled. Any suggestions? |
Might want to take a peak at a service manual before you destroy your enginezzzz
Tom P.S. To answer your question... No you cannot split the block halves that way... You could do it the right way though |
I have seen the manual and have used it for most my tear down. It just calls out a couple tools that I don't have (circlip pliers and pin puller), and Subaru is being a serious pain about ordering them. They say they don't normally order tools for customers, and it would take over a month.
Does anybody have a suggestion on how to get the correct pin puller? If it takes a while, it takes a while, but one can always hope for a speedy solution. Just curious, but why would it not work? Are the cylinders tapered so the pistons only come out one side or what? |
Harbor Freight hemostats for clips
Tapered piece of wooden doweling from Home Depot (yeah, you've got to use a belt sander to put the taper on it) for the pins
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$ |
Sounds cheap and simple. Thanks for the suggestion
Lynnwood isn't that far from Tacoma! Would you charge admission for people to come and watch this?
Keith ![]() |
i had to help a friend move today, so i will have to do get the stuff tomorrow. so if you will be free later in the day
I know it has been a while since I have posted on this, but progress has been made and I will post pictures later tonight or tomorrow. I have the engine completely broken down. Modified slide hammer did the trick. It will be going to the machine shop later this week hopefully.
So, here are the mods I have decided to go with. -Stock crank and rods, with 11:1 Forged Pistons from ECUtune -Stock valve gear, with replaced valve stem seals -.256 duration (exhaust and intake) Camshafts from ECUtune -Z32 MAF, SR20DET injectors (370cc), 2v7 ECU from ECUtune Other than that, things will be stock, minus some powdercoating and rattlecan (high-temp). Gotta make things look nice ![]() As for what the machine shop will be doing -Resurfacing heads -Balance of the rotating assembly -Bore and Finish Hone of cylinders -and a valve job (regrinding seats and faces, and replacing the valve stem seals) -Hot Tank EVERYTHING (well, everything that can be that is) Well, more updates to come as things unfold. I hope to have this whole thing done within 6-8 weeks. All depends on when my parts come in though. Wish me luck! |
