1992 cold starting problems
Hi , i have a 92 lsl with a 5 speed mod (not purfect :-) ) the car has issues starting now the weather is colder. Its ok once its warmed up.(Canada eh ) Is cold starting a SVX known issue ? Could it be related to the 5 speed swap? Its as if if need choke.
Thanks C
92 Teal 5 speed |
Re: 1992 cold starting problems
See if slightly depressing the gas pedal makes it start faster. The auxilary air control is responsible for providing more air for a cold starting/running engine so that would be a good place to start, providing you have ruled out weak battery issues first.
I'd check/replace the coolant temp sensor, not the one wire one, but the other one, as it will cause cold start problems also...
Thanks guys yes new battery , no change, yes i tried different gas positions with no change, i will check the coolant temp sensors , when i find them :-) Any clues to finding them?
Cheers Clive
92 Teal 5 speed |
The coolant temp sensor is pretty easy to get to. Here are directions that Hocrest gave me before I did mine:
"Not too bad, the only thing you need to remove to get access is the plastic H-6 Cover.
1992 LSL ebony pearl 171k - Thank you Ron Mummert Reading Box of Wine Car 1997 Lsi 2007 WRX 5-Speed Manual, Gloss Red Vinyl Wrapped, Brz Seats 189K ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Thanks Sean486 , very useful, a job for the weekend!
92 Teal 5 speed |
OK solved the cold start issue; the lever/sensor that used to fit on the auto tranny to give gear position was not in the neutral position. as soon as i moved it to the neutral position it has started perfectly even on the coldest mornings.
Thanks Clive
92 Teal 5 speed |
Interesting.....
Hi Huck369, in your write up i think you call it the neutral safety switch, its a half moon piece of metal with a pivoting slider on it, and as you describe there is a neutral position indicator (thats how i found it)
Hope this helps as i read you removed yours ![]()
92 Teal 5 speed |
Yep, I removed mine on the SVX when I installed the 5-speed, and it starts perfect.... But my XT6 which I installed the EG33 into is REALLY hard to start when it's cold....but starts perfect after it's been warmed up.....it also has no Neutral Safety Switch, and is set up the same way my SVX is, so I haven't been able to figure it out...
