Thermostat Replacment
So I believe that my thermostat is now stuck closed. Where exactly is it? I have heard that you have to get to it from underneath. I did a quick search and couldn't find anything on this subject. Thanks guys
Re: Thermostat Replacment
Remove the belly pan and you will see where the thermostat cover (10160) connects to the lower radiator hose at the engine. Once you remove the two 10mm bolts that hold the cover, the thermostat (21200) and gasket (21236) can be removed. You will need a bucket to catch the coolant and a 10mm socket. Be sure to let the engine cool down first and then remove the radiator cap. Use an OEM thermostat and don't forget to get a new gasket as well. Both of these parts should be less than $15.00. ![]() Put the old thermostat in a pan of water and bring it to a boil. Put a thermometer in the pan to see when it starts to open (if at all) If the water boils before the thermostat is fully open, it was bad. ,
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-15-2009 at 01:54 PM. |
It's right inside this pipe...
97 Toyota 4Runner SR5, 5 spd 92 Ebony SVX AWD (4.44 gears) |
Thank you. Looks like a job for my friend with a lift. I don't crawl under cars anymore...lol
You may be able to access it from above if you remove the radiator fan on the driver's side.
![]() As others said, it's important to use OEM parts. The Autozone type have a high failure rate. Mike
