Old 05-25-2009, 12:20 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: cats and exhaust
Crap, the site must be down.....
It should be pretty straightforward to have a single outlet..... you would just cut out the 1-2 split muffler and put in a regular straight muffler..... the only thing is the rear skirt is set up for dual pipes..... might look a little hokey with just one.
Old 05-25-2009, 12:58 PM
Famouspork Famouspork is offline
I'm missing one chrome tip anyway so I don,t really care...I'll cut through the plastic to install the rice cooker..
Old 05-25-2009, 01:05 PM
Bobb Bobb is offline
Hi Chris, Just about anything you do to the exhaust system will effect the power output. The SVX has a "tuned" exhaust. The little "muffler" after the cat is a resonator. Without that, your performance will take a hit. If its already leaking along with the rest of the exhaust ypu are losing power. If all you want to do is keep from getting carbon monoxide poisoning, you can do what ever you want. Take care, BOBB
Old 05-25-2009, 01:26 PM
thanks for the advise, but My name is Jason lol,
yeah the resonator has been deleted by the previous owner,so that's a non-issue, but it's leaking EVERYWHERE along the line, the job was done very poorly, and I can smell the fumes everytime I push the car on the highway.
I'll go with the simplest, most straighforward system.I have a feeling the cats are clogged, but the car doesn't smell of sulfur at all...
Old 05-25-2009, 01:34 PM
DarknessofDeath's Avatar
DarknessofDeath DarknessofDeath is offline
Inhabitant of Darkness
if you want more power, install a NOS kit...not the drink ~
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 05-25-2009, 01:42 PM
My opinion is that kind of power is a worthless waste.
I prefer steady and continuous power over a short burst of a stuff you run out of after a few shots and then you lose anyway.
My goal here is to make the car run fine.
But thanks for you input!
I'm quite the diplomat
Old 05-25-2009, 02:09 PM
If the cats are clogged, your gas mileage will suffer greatly and eventually, the motor will not run at any higher rpms than idle-It will stall out from back pressure...
Old 05-25-2009, 02:34 PM
Okay, well for now, the cars revs fine..but the line looks like swiss cheese, it's not any better...what could it be then? Why is the car surging under heavy acceleration, like it suddenly gives all it has? I don't have misfire, just a plain choked up acceleration. I have to find the problem, or I'll just change the motor
