Old 04-03-2007, 06:54 PM
rivman1243 rivman1243 is offline
Originally Posted by AJ4U2
This is the same one i use to, 10-30 pennzoil....
Aj.
i wonder if the bigger filter has a negative effect on the oiling system like lower flow rate or something? has anyone thought about that or am i out in left Field?
Old 04-04-2007, 12:10 AM
I don't think it would have any negative affect on it.
Old 12-29-2008, 03:44 PM
kamil212 kamil212 is offline
Re: oil change question
Hi guys,
I just picked up a SVX and need to change the oil as the car was sitting for a few months.
What washer do I need for the drain plug?
Is it a standard one across all Subarus?
(I don't need any for my Forester since I have a quick drain valve installed, so I might have a few of those washers laying around)
I'm also thinking high-mileage oil as the car has 185K on it. Any suggestions? (the Quaker and Castrol GTX is on sale at Autozone right now)
1997 SVX LSi in Ebony Pearl Black #401
2008 Forester STi in WRB
Old 12-29-2008, 03:53 PM
kwren's Avatar
kwren kwren is offline
Originally Posted by kamil212 View Post
Hi guys,
I am not a huge believer in changing that washer with every oil change.
If you get the filter from a Subaru dealer they will have the washers there. If you don't, they will have the washers at a Subaru dealer and the filters are at least a good choice from a dealer anyway.
Keith
Old 12-29-2008, 03:56 PM
kwren's Avatar
Looks like you are standing out there in Left field
The worst result would be a positive one with no adverse affect on the engine oil pressure.
Keith
Old 12-29-2008, 04:09 PM
Keith
Thanks, but my question was if you know if it's the same washer as all other subarus as I might be able to dig a few up that I had for the Forester.
Old 12-29-2008, 07:15 PM
kwren's Avatar
I believe it is but not sure, I could be out there with you in left field.
I am pretty sure but you need to compare... Sorry
If I can find a way to check I will but too late tonight. You could call a Subaru dealer and ask if the part #'s are the same?
Keith
Old 12-29-2008, 07:42 PM
Bobb Bobb is offline
Hi Keith, Yes,the drain plug gasket is the same as other Subarus. Mobil 1 recommends a 10W30 if the temp does not go below zero. 5W30 if it goes below zero. Happy changing and take care, BOBB
Old 12-29-2008, 08:04 PM
Thanks you 2 for the help.
I just found one laying around so all I need is the oil and filter.
