Old 11-28-2008, 08:32 PM
mo_thug_85 mo_thug_85 is offline
AWD problems
hello i am a new owner of a 1992 svx. i am having problems with the awd its not working and i am getting a noise from around there. when it is in drive. what could be wrong with it
Old 11-28-2008, 08:48 PM
oab_au oab_au is offline
Re: AWD problems
How do you know that the AWD is not working?
Does it spin the front wheels?
If they do, is that when you hear the noise?
Or do you hear the noise when you are just driving along?
One Arm Bloke.
Tell it like it is!
Old 11-28-2008, 09:37 PM
Re: AWD problems
it spins the front wheels and the noise is when i am driving down the road and when i stop it goes away
Old 11-28-2008, 10:12 PM
Re: AWD problems
You probably have two problems.
The lack of AWD, do you get the power light flashing, at start up?
The noise in the transmission, could be a few things like, the front diff, a front axle joint.
Does the noise change when on/off the throttle?
Does it do it when turning?
What does the noise sound like, a clunking, a whirring, a clicking?
One Arm Bloke.
Tell it like it is!
Old 11-28-2008, 10:25 PM
Re: AWD problems
where is it located
Old 11-28-2008, 10:32 PM
Re: AWD problems
where is it located
What bit?
The power light is on the dash. The diff is just behind the engine. The axle joints are each side of the front wheels.
One Arm Bloke.
Tell it like it is!
Old 11-28-2008, 10:36 PM
Re: AWD problems
what would cause the awd to go out like that
and ya it does go away when i let off the throttle
Old 11-28-2008, 10:48 PM
Re: AWD problems
I tend to think it is the front differential making the noise.
If the power light flashes on start-up. Then there is a code stored in the computer telling what the trouble may be.
One Arm Bloke.
Tell it like it is!
Old 11-28-2008, 10:50 PM
Re: AWD problems
how do i read the computer
Old 11-28-2008, 10:59 PM
Re: AWD problems
Go to this website;
http://www.svx-iw.com
click on "SVXipedia" and look for the section on how to check tranmission error codes to find out what it is complaining about
One Arm Bloke.
Tell it like it is!
Old 11-28-2008, 11:47 PM
Re: AWD problems
what do u think will make the awd not work
Old 11-29-2008, 04:19 PM
Re: AWD problems
how can i fix the front differential
Old 11-29-2008, 05:00 PM
Francis Francis is offline
Re: AWD problems
dude...look around this forums about your last question there is tons of information about this car ...just click search type "keywords" and TADAMMMM
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Display Modes
