Old 11-02-2008, 01:11 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
power steering leak
couple weeks ago i had to refill my power steering fluid
and since then ive been noticing that after driving around there is smoke coming from under the hood
after some examination, i noticed there was ATF fluid dripping on my exhaust manifold (pass. side)
checked the power steering fluid level and it was empty
so, my question is, what is the hose size for the power steering line?
idk if i have a hose or clamp issue, i still need to give it a closer look
and has anyone else experienced this before that could possibly give me some advice on what to do?
thanks
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 11-02-2008, 09:29 PM
Re: power steering leak
I had exactly the same problem when I bought mine in August. The high pressure hose had a tiny crack in it and while driving it speewed fluid on to the passenger side exhaust. When I stopped the smoke would billow out from under the hood. I replaced mine with a new OEM hose (about $115.00) but apparently you can have it rebuilt at a shop dealing in hydraulics, backhoes etc.
Old 11-03-2008, 10:49 PM
tiv0's Avatar
svxless
is replacing the hose yourself a difficult thing to do?
Trevor
Avondale, AZ
1987 BMW 325is
Old 11-03-2008, 11:58 PM
No, it is quite simple.
Old 11-05-2008, 09:03 AM
svxash's Avatar
svxash svxash is offline
Ours had been leaking some and the other week when my wife went to leave it started dumping fluid all over the ground. It ended up being one of the hose clamps that came loose. It was on the passenger side of the car. I just put it back on and tightened the clamp and all is well again. I'll take a pic of the line that came off. It is located under the EGR valve and has a small screw clamp on it that holds it to a metal line.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 11-05-2008, 05:50 PM
svxash's Avatar
Here's the pic
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 11-08-2008, 06:26 AM
pgould66 pgould66 is offline
hmmm - this sounds vaguely familiar - except on mine the smoke billows out of the driver side whell well. I've been told it is the steering rack leaking and that I should replace the whole rack ( $1200) and another shop told me the line from the tranny to the radiator was leaking, which should have been resolved when I had the trans cooler installed but she is still smoking.
A crack in the high pressure hose sounds plausible as this usually happens after a spin down the highway at speeds.
Power steering and tranny fluid levels do not go down so where is the fluid coming from??
Old 11-08-2008, 08:12 AM
Francis Francis is offline
yeah i just changed that **** too like a month ago ....it was hard to remove it , but to install it !! goosshh i had no lift only a standard jack....i think the best way to have less problem, jack your passenger side of your car. remove the passenger wheel , there will be 2 little plastic cover, remove them ...TADAMMMM
you get a good access to the hose,you will see a nut at the end of the hose just like the top end unscrew it with a big key...i think it was 5\8 and the hose itslef is held by a bracket with a bolt ...14 mm if i remember correctly , it did not cost me nothing , i just took it from my wrecked
((EDIT))....after looking correctly i think its not the same hose as me...
((EDIT #2)) ....my old story http://www.subaru-svx.net/forum/showthread.php?t=46011
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
