Old 09-27-2008, 09:56 PM
Twinboosted's Avatar
Twinboosted Twinboosted is offline
Nissan guy
My built VG30DETT 300ZX engine is completed!
I know this a little bit off topic, but I figured someone would like to see it. It is my VG30DETT out of my '90 300ZX Twin Turbo. Just had it built at Import Parts Pro and should easily sustain 1,000 HP. It has :
Weisco Pistons with full ceramic/moly coatings
Eagle Rods
ARP Rod Studs
ARP Main Studs
Block Inspected and acid dipped
Block redecked
Block water passage bored out for more water to back cylinders
Block Bored and Honed using a Torque Plate
Crank knife edged
Crank center weight tig welded into place
Crank balanced
New Moly Coated Race Spec Main bearings installed
New Moly Coated Race Spec Rod bearings installed
Block prepped and assembled
ARP Head Studs
Tomei Cams(270 duration / 10.25mm lift)
Tomei HD Valve Springs
Tomei Solid Lifters
Titanium Retainers
Ferrea 1mm Oversized Valves
Heads inspected and cleaned
Heads Pressure Tested
Heads redecked
Ported exhaust and intake runners
5 angle radius cut valve job
Combustion Chamber work
Valve heights set
New OEM Valve stem seals
Heads prepped and assembled
New OEM Cam Seals
New Cometic Metal Head Gaskets
Total: $10,000
Continued.....
______________________________________________
1990 Nissan 300ZX TT
Nissan guy
Re: My built VG30DETT 300ZX engine is completed!
Continued....
Once this thing in broken in, I will be pushing around 700WHP. I can't wait!
Old 09-27-2008, 10:17 PM
Old Fogey
Very nice! Should be a street monster.
$10K eh?? You must be a retired Wall Street CEO!!
Glenn
Old 09-28-2008, 01:17 AM
Beautiful!!! Congrats!!
Old 09-28-2008, 01:31 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Someone bent your block!
Its in some weird "V" type shape!
Just kidding. I know some people have this weird fascination with "non-boxer" motors for some reason.
Good luck with it and I hope you put down the numbers you're looking for!
Dustin
-Dustin
Old 09-28-2008, 10:37 AM
Nissan guy
Haha. I actually love boxer engines. I used to race Subarus back in the day.
Old 09-28-2008, 11:03 AM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
I want that motor for my S30Z. Great work. Now go teach Supras a lesson.
Old 09-28-2008, 11:11 AM
This is one of the best engines ever... I wish the new 350Z engines were closed decks
Old 09-28-2008, 01:14 PM
Nissan guy
Import Parts Pro does 350Z engines as well.
Old 09-28-2008, 02:07 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Beautiful! Looking forward to hearing about the numbers it puts down.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-28-2008, 04:25 PM
Closing decks?
And do you care to shed some light on:
"Crank knife edged
Crank center weight tig welded into place"
Curious about the pros of these mods...
Old 09-28-2008, 06:52 PM
BeneathNorthernSkys's Avatar
BeneathNorthernSkys BeneathNorthernSkys is offline
Work, Sleep, SVX, Repeat
300zx's are up there with my favorite 2 door coupes. Make us proud and unleash that monster engine you got!
Jordan
1992 SVX LS-L 126,xxx Sold
1990 Non-Turbo 300zx 127,xxx
1991 Non-Turbo MR2 214,xxx, replaced engine at 190,xxx
Watch your thoughts, for they become words.
Watch your words, for they become actions.
Watch your actions, for they become habits.
Watch your habits, for they become character.
Watch your character, for it becomes your destiny...
Old 09-28-2008, 06:54 PM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
Can I has for my 300ZX?
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 09-28-2008, 07:58 PM
Nissan guy
Originally Posted by SilverSpear View Post
Closing decks?
"Crank knife edged
He can have anything done. As for the Knife edging, it lightens the rotational weight improving rev-up time, meaning that there is less resistance against the engine. Quicker rev-up makes for quicker spool up, resulting in a wider powerband. It also makes for less resistance against the oil that the counter weights dip into and makes for less aeration of the oil in the pan. Inline and boxer engines can have FULL knife edged cranks which results in even better performance since more can be removed.
The Tig welded weight is, in my best guess, a precautionary measure so that the weight does not back out. The weight they add is to balance the crank at high speeds. My particular engine will have a redline of 9,000 RPM.
Here is a link to a specific package that he offers for the 350Z engine. Notice the 1200 WHP capability on it.
http://www.importpartspro.com/st4vqloblni2.html
Old 09-29-2008, 01:15 AM
I know I am pushing with this, but might you have some pics about the tig welded weight? Because I cannot notice it in the pics you posted
Rate This Thread:
