Old 06-06-2008, 09:49 AM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Thanks for the tip on the sensor. Yes, we conducted the test in the shop. I'm not an AC expert so that is why I had my mechanic perform the procedure.
I'm starting to wonder if my compressor is not functioning properly. It has plenty of charge but the line ( we had gauges on it) going to the firewall isn't cool. The odd part of it is I thought my compressor would be very noisy if it was bad. Possibly not...
Old 06-06-2008, 07:46 PM
Hondasucks's Avatar
Subaru Technician
Could be the reed valves. What did the gauges read? Should be ~30psi on the low side and ~150-250 on the high side at idle. (Actual readings will vary with ambient temperature, etc...) if you have like 60-80 psi on both sides of the compressor with the compressor running, your compressor is toast, assuming there is a full charge of refrigerant in the system. I've seen them have just enough in the system to keep the low pressure cutoff switch closed, but not enough for the compressor to circulate.
Would help a lot if you posted gauge readings :-) I have a nifty chart that shows you what the different gauge readings mean.
1986 VW Jetta
Old 06-07-2008, 04:35 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
hmm, interesting.....
i hav a 94 too and the A/c blows hot air.....i think i have a leak somewhere but idk where it could be.....does anyone have any ideas on where to look and how to fix it w/o going to a shop ?$$$$
Old 06-07-2008, 10:16 PM
kwren's Avatar
kwren kwren is offline
O rings would probably be a good place to start...
Old 06-07-2008, 10:55 PM
Hondasucks's Avatar
Subaru Technician
It's probably low on refrigerant, it does slowly leak out over time, an evac and recharge is like $100-$150. AC problems aren't all that easy to troubleshoot without a set of manifold gauges.
1986 VW Jetta
Old 06-09-2008, 10:01 PM
VICSVX's Avatar
Never Forget
well i had it evaced adn rechached last summer and it worked just fine
it worked in the winter too
but now its just blowin hot air
its about 100 now n days, and i get hot fast
i tried lettin the car run with a/c on and windows cracked a lil bfore i got in
but it was hot as a mofo!
Old 06-10-2008, 08:20 PM
Hondasucks's Avatar
Subaru Technician
See if it gets cold when you are driving, if it's hot out, it won't cool as well with the car just sitting, although it shouldn't all leak out in a year. Look carefully at all your AC lines, there will be an oil stain/dirt accumulation around a leak, due to the oil that's in the refrigerant. Pay close attention to all the unions/fittings, could be a bad O-Ring, I've also seen a few cars with rocks in the condenser, that could be it as well.
1986 VW Jetta
Old 06-11-2008, 11:27 AM
VICSVX's Avatar
Never Forget
ok i'll look at it and see what i can see
i tried drivin around yesturday with the ac on and it just kept blowin hot air....i think im outta freon:'(
Old 06-15-2008, 06:32 PM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
Re: Air Conditioning blows hot air
Figured I would use this thread. My Compressor will not kick on.
I have done the internal self test, and it appears to all come up normal.
I don't know if I'm just out of juice, or toasted the Compressor last week when the belt went out, {not using the air when it happened}.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 06-15-2008, 11:25 PM
kwren's Avatar
Not sure about your "internal self test" but there is some information on this thread and a couple of other resent ones that will get you going in the right direction.
Keith
Old 06-16-2008, 10:57 PM
Keith
Thanks, I got it. And there is a routine in the "How To's" to do a self test of the system, to find out if all the circuits are working.
Mine turned out to be completely empty of Freon, and it took about 5 seconds of refilling to get it to engage.
I was not aware that the compressor would not kick in without pressure.
The Worm
_______________
No Mods, 33K Miles
Old 06-23-2008, 09:25 AM
SVX JAZZ's Avatar
Tired
Air is fixed... Turned out to be a bad schrader valve. Replaced and re-filled and all is well. Now, on to replacing the left rear wheel bearing!
Old 06-23-2008, 09:30 AM
kwren's Avatar
Good Job and good luck with wheel bearing project!
Keith
Display Modes
