Old 06-03-2008, 12:32 PM
kwren's Avatar
kwren kwren is offline
Bummer...
Originally Posted by scottsubarus View Post
Keith.....you don't.
If you were to remove it, it's almost impossible to drain if flipped over. It's never adviseable to drill a hole and attempt to re-weld as it wouldn't be balanced.
Guess there is no way I can replace the fluid with a good synthetic type
Old 06-03-2008, 02:36 PM
Maxo's Avatar
Maxo Maxo is offline
maybe not?
It would definitely cost a little more due to wasting some synthetic but I've read that in order to replace all the fluid one could just:
1. Drain the conventional fluid as usual then refill with synthetic.
2. Disconnect the transmission cooler return line so it runs into a container.
3. Pull the parking brake and/or have someone with their foot on the brake pedal then start the car and put it D.
4. After draining 4-5 quarts or when color changes to the synthetic's shut off the car.
5. Reconnect lines and top off with the synthetic.
Any reasons why doing the above wouldn't work on the svx?
Old 06-03-2008, 03:53 PM
oab_au oab_au is offline
Yes Max, thats the way to do it, don't have to put it in D, Park will have the pump running.
One Arm Bloke.
Tell it like it is!
Old 06-03-2008, 05:54 PM
lechnoid's Avatar
lechnoid lechnoid is offline
Tech & Almost Lawyer
If you're looking to totally clear it all, wouldn't it also be a good idea to run it through all gears, spending maybe 30 seconds in each? This would clear the non-synthetic out of the valve body as well. Or am I suffering from shoe in mouth again from dealing with too many retarded customers today?
Old 06-03-2008, 06:00 PM
Yes mate, that too, there is a fair bit in all the other places too.
One Arm Bloke.
Tell it like it is!
Old 06-03-2008, 06:24 PM
lechnoid's Avatar
LOL, good, the customers haven't driven me completely batty today.
...there's always tomorrow...
Old 06-03-2008, 06:38 PM
BeneathNorthernSkys's Avatar
BeneathNorthernSkys BeneathNorthernSkys is offline
Work, Sleep, SVX, Repeat
just to bump my question, gear oil for the front diff, what weight is it? I've heard several different suggestions, I was told by the tranny shop it was 90w, another person said 75w who has a legacy, which I know is different so Idk about that one.
Jordan
1992 SVX LS-L 126,xxx Sold
1990 Non-Turbo 300zx 127,xxx
1991 Non-Turbo MR2 214,xxx, replaced engine at 190,xxx
Watch your thoughts, for they become words.
Watch your words, for they become actions.
Watch your actions, for they become habits.
Watch your habits, for they become character.
Watch your character, for it becomes your destiny...
Old 06-04-2008, 01:04 AM
anyone know what gear oil to use for the front differential? Again I was told 90w, but is that correct?
Jordan
Old 06-04-2008, 05:20 AM
dcarrb dcarrb is offline
The owner's manual shows 90W for temperatures 30F and above; 80W/90 for all applications. Front diff capacity is 1.3 qts/1.2 liters.
I don't believe anyone hit on the actual capacity spec for the transmission, which is 10 qts./9.5 liters. For one more opinion on fluid type: I just run plain old Dexron as specified, and change it often. One of mine has an external cooler and filter, the other is bone stock.
dcb
Old 06-04-2008, 06:20 PM
Wolfy's Avatar
Wolfy Wolfy is offline
Send a message via AIM to Wolfy
is there a gasket in the front diff like the cover gasket for the rear diff?
Display Modes
