Old 05-13-2008, 04:41 PM
Manarius's Avatar
Manarius Manarius is offline
Epic Sparkplug Fail
So, I was doing the plugs today - the passenger side back and driver side back were definitely the worst as they usually are. However, the passenger side back had a special treat for me.
That's my extension pushed through the access hole. It should be straight - instead it's cocked at an angle. For some reason, the plugs don't line up on the passenger side. Epic access hole fail. I had to do the passenger side back one by hand and let me tell you it was a pain. I finally got the plugs done though. Car drives much better it seems.
I also did the driver's side without the access hole. Again, a major pain.
-Jason
-Obi Wan Kenobi
Old 05-13-2008, 05:11 PM
Only the driver's side has the access hole. The pass side has just enough clearance to use a spark plug socket and a 3" extension.
Old 05-13-2008, 05:44 PM
Manarius's Avatar
Not really. Trust me, I tried. I did a lot of hand turning - good thing I have smaller hands.
-Jason
-Obi Wan Kenobi
Old 05-13-2008, 06:08 PM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
Yea doing plugs on a boxer is a pain. Platinum FTW!
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 05-13-2008, 07:41 PM
Manarius's Avatar
Only with DOHC. The SOHC engines have 45deg plugs which are oh so easy.
-Jason
-Obi Wan Kenobi
Old 05-13-2008, 07:46 PM
immortal_suby's Avatar
Thread Killah
Did the plugs on the wife's FXT sunday and it sucked almost as much as the svx. No access holes. Dropped the ratchet into the bellypan at least 47 times.
I did like that the wires for each coil unplugged at the coil. It should make all 4 coils interchangeable.
Locker Link
2015 BRZ Limited 6MT
Old 05-13-2008, 07:48 PM
Thread Killah
I used to change the plugs, cap, and rotor on my little red wagon just for fun on a saturday. There was so much room to work in that engine bay, you could put a spare tire in there.
Locker Link
Old 05-13-2008, 10:20 PM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
i couldnt believe how hard it was to change the svx plugs..... and to think that i didnt even know there was an access hole on the drivers side!!!!!! man, i think i might change them again this weekend just so i can try it out haha.
it took me an hour or 2, the passenger side was a breeze, but the 2 rear drivers side ones where the biggest pain!
1992 silver/black LSL - 142,xxx miles
power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler
1971 toyota landcruiser - project.... someday
Old 05-14-2008, 12:41 PM
subiedo subiedo is offline
I'm a little surprised although I had read about the access issues before. When I swapped plugs, the drivers side rear was the stinker but a short extension with a flexible "knuckle" worked great. Think I had them replaced in a tad over 1 hour which was less time / frustration than the (Ford) Aerostar 4.0 litre generated. It may be a pain if I do them again (cuz I'm starting to think I had some luck when I did them) but buying the ($$) Iridium plugs should extend time between changes considerably.
Old 05-14-2008, 12:50 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
i feel everyone's pain
i changed my plugs recently, only 5 though
i honestly could not get the driver's side rear
didnt try the access hole, just didnt have the time
the plugs i replaced werent that bad, so leaving that one in there really wont do much damage
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 05-14-2008, 02:38 PM
Manarius's Avatar
So now, my car stumbles even worse then it did before. New Iridium plugs that stumble. Great....
-Jason
-Obi Wan Kenobi
Old 05-14-2008, 02:51 PM
Hocrest's Avatar
Hocrest Hocrest is online now
Freezepop's are Awesome!!!!
How were the coils?
Any tears in the boots or insulation pulled away exposing bare wires?
Old 05-14-2008, 03:00 PM
Manarius's Avatar
Originally Posted by Hocrest View Post
How were the coils?
Coils looked brand new. Insulation pulled away? Yes.
Should I have done some sort of relearn procedure? I didn't think to do it at the time.
-Jason
-Obi Wan Kenobi
Old 05-14-2008, 03:15 PM
Hocrest's Avatar
If the insulation was pulled away exposing metal, that is probably your problem. I've used the putty epoxy to build up little areas to keep the wire separated. Make sure you use one with no conductivity.
Old 05-14-2008, 03:17 PM
Manarius's Avatar
I didn't see any metal, just wire. Hence I wasn't worried. Black insulation was pulled away to show red wire.
-Jason
-Obi Wan Kenobi
