Old 02-23-2008, 03:46 PM
crazyhorse's Avatar
242,000 mi on oem trans
Diff parts to trade
I'll be replacing the trans in my SVX soon, with an Impreza unit. I'll have a full set of 3.54 gears, front, and rear, that I'd be willing to trade for a 4.11 rear LSD.
What you get: full front differential, ring, spiders, pinion, layshaft. Full rear differential , housing, gears, LSD, pulled working, from my SVX.
What I want, a working 4.11 LSD, ready to bolt into my SVX.
I'll pay shipping on my parts to you, you pay it on your parts to me.
It may be a couple weeks before I get the parts out of my SVX, so ATM this is a feeler.
EDIT: Corrected gear ratios
"42"
Current Stable By Age:
Old 02-23-2008, 04:17 PM
sicksubie's Avatar
interested in buying it possibly....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 02-23-2008, 04:24 PM
crazyhorse's Avatar
I'd really like to find a trade, as I'm getting the 3.90 trans, w/o a diff. If I don't find a trade, I'll give you a yell though.
You know a Subie without AWD is like socks with sandals, it just ain't right!
"42"
Old 02-24-2008, 06:51 AM
Paul,
I don't know for sure what ratio that tranny is...may be a 4.11 or a 3.90....
So you may want to find out for sure first....
If I get back over there, I'll get the numbers off the tranny (I should have done that when I pulled it...but I forgot)
You can always install the tranny, and run with the FWD fuse in untill you get a rear diff for the swap.
Old 02-24-2008, 12:36 PM
OK...ran over to my Father-in-laws after church..
Got the numbers off the tranny, maybe someone here can verify the ratio
info 96 Impreza L AWD Sedan
Vin
JF1GC4357TH512578
BUILD DATE 12/95
TRANNY NUMBER: T2 102ZA4BA-GF
Old 02-24-2008, 01:00 PM
crazyhorse's Avatar
Thanks Huck
I know there's a list somewhere of trans codes & thier ratios. It's how I verified the wife's Lego has the 4.44 gears.
(the thought crossed my mind to swap her trans into the SVX)
I figured on running in FWD until I can get ahold of a diff. I figured to pull the diff & axles out of the rear until I can find one, to save wear & tear on the LSD. Just in case I need to swap in new gears.
Dug it up on USMB ZA=2.2l & 4.11
"42"
Old 02-25-2008, 05:10 AM
Thanks Huck
The axles are what hold the wheel bearing together....
If it has the 2 part drive shaft, just pull out the rear section of the driveshaft...
Rate This Thread:
