Sisters SVX started acting up today
Well, my sister's 1992 LS-L started acting up today for the first time since we have owned it. She went out to start her car for the first time today at 7:00 PM and it wouldn't start. She only tried to start it the one time though before she came and asked me to look at it. I went out and started it my first try without hitting the gas or doing anything extra, but it started kinda rough. After about 5-10 seconds it started to run a little better, but the idle was up a little over 2k and the check engine light came on. I let the car run for about two more minutes then I shut it off to check a few things. I couldn't find anything that looked wrong or find anything disconnected and all fluids are good. After all that I started the car up again and it started normally, idled correctly, and there was no check engine light on anymore. It was running fine for about 2-3 minutes when the rpms start going back and forth from around 750/1000 all the way down to around 200/250. After about 8 times of back and forth the rpm decided to sit at around 200/250 and the car sounded like it was about to die. I finally just shut it off and figured I'd get a few other people's opinions on the situation. I should probably mention that the car has a brand new alternator, the battery checked out at 14.2v, and I replaced the CTS about a month ago. Any advice on things to check or what you think it might be would be appreciated. Thanks
Vacuum leaks, idle air control valve... something of that nature probably.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
Yeah thats kind of what I was thinking too. Thanks for the fast reply.
CTS probably... (Coolant Temp Sensor)
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
Thread Tools | |
Display Modes | |
