Old 11-03-2007, 01:57 AM
Originally Posted by DarknessofDeath View Post
it didn't take too long for me to get repairs up to $30k,...especially with the price of parts
What have you done?
I intend to hit 40k. I want to fix the ABS, revamp the stereo system, get cams, do a little dent fixing, repaint, tint the rear, new struts, and a few other little custom things.
Good thing I'm not married.
Old 11-03-2007, 04:41 AM
DarknessofDeath's Avatar
Inhabitant of Darkness
ok..lets see if i remember..
car i bought for 3500$
had to change left downpipe that has the cat in it. rebuilt the compressor twice (once under warranty), and the alternator a few times (eventually i bought a second rebuilt alternator as a spare). needed condensor, bought it off ebay and it was shot before i got it, bought one locally for $350 used - had no other choice unless i was going to the dealership.. evntually had to replace the high pressure line (oem)/
new tires - bfgoodrich traction t/as
changed out vaccuum hoses under the manifold plenum..needed the idle purge selonoid (oem)-car sat for 2 weeks because of this one
original rad leaked, so i bought a used one, that one leaked eventually so i went with a PWR in the end.
hi flow cat, stebro....drill/slotted rotors.. new pads.
added tranny cooler. intersate battery
bought new oem struts and strut mounts on all 4 corners, motorsport lowering springs. replaced all 4 links rods( OEM), all 4 lateral rods on the rear end( OEM), both rear spindles( OEM)- car sat on a hoist for 2 weeks because it had to come from japan, all 4 wheel bearings (oem). upgraded sway bar bushings front and back from the group buy/ never installed the rear dif bushings. changed out all 4 cv axle shafts (OEM).
bought the little plastic lever on the driver side seat -oem (pull to let passenger to back seat)
...dammit..i used to have a list....
ecu tune stage 1. all three belts, motorsport lightweight pulley, crank seal and cam seals. dropped a jdm motor in it (when the head gasket went). k and n air filter. changed the spark plugs with ngk iridium ix. ....sunroof weather seal (oem)....compustar...voltage stabilizer
...i dont remember....all the little things like all the headlights, interior lights.. the dash illumination lights...speakers, cd/mp3 player
...something like that...
would be less if i werent' in canada though...i know you guys get parts much cheaper than i do up here..but pretty much everything were subaru oems. i know parts cost me more than the labour did in all this
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 11-03-2007, 08:44 AM
Eh? I need a release fork. 30-40 dolla part depending.
Oh, one more thing, he says it's an 02 tranny, not an 04... and 1stsubaruparts says 02 gets it's own special fork.
I think he is refering to whether or not his car has 30k into it... I was confused by that at first.
tom
Old 11-03-2007, 06:19 PM
Oh haha. Makes sense now. That didn't even click in my head.
Old 11-03-2007, 06:56 PM
I just added the text document I'm using to keep track, if anyone is interested in the breakdown. It's fairly user-friendly.
It's in the first post.
I just looked at it and the formatting is screwed up. Too bad you can't upoad RTF attachemnts... *hint*
Old 11-04-2007, 01:17 AM
Hondasucks's Avatar
Subaru Technician
Purchase - $800
Transmission - $300
Misc parts (Ball joint, tranny fluid, oil, oil filter) - $100
Title & Registration - $147
$1347
I've got a ways to go...
1986 VW Jetta
Old 11-04-2007, 06:56 AM
hey, well...i dont think anybody is looking to spend 30K on maintenance on a short time...less than 2 years
i think in my case i was pretty much restoring/rebuilding...but some things had to be done , not out of choice
Old 11-04-2007, 12:54 PM
subarufamily subarufamily is offline
you dont have to be single to get close to the 30k club, you just have to have that understanding "special" wife, and alot of available cash.
1 rebuilt tranny $4900
1 tranny cooler $100
2 mafs $250(1 well used and 1 gently used )
s/s lines $100 ( brake line devoleped a hole)
set of rotors $300 ( i know they dont warp the new ones just dont vibrate )
1 hood, fender, headlight , grill, fender support , bumper (all) $2800
1 Repaint said items $2200
1 car repaint ( to remove hail damage ) $6500
2 rear wheel bearings $150
anyway you get the idea
William
Old 11-04-2007, 12:59 PM
I could start crunching numbers for mine but I think I am still under the 25k mark Thats with NO labor charges
Old 11-05-2007, 06:34 AM
dcarrb dcarrb is offline
Two tone wheels, a high-pressure PS line, an ABS sensor, and front wheel bearing replacement cost about what I paid for my silver SVX, so now I drive it twice as often to get my money's worth.
Thirty grand on one... Geez; I like the SVX, but that's out there. I doubt I'm one-third of the way to that number with two, and that's purchase price, tires, oil, even gas.
dcb
Old 11-07-2007, 07:04 PM
MNYPNNY's Avatar
MNYPNNY MNYPNNY is offline
FKA....thndrmtn92svx
Alcyone Silver Contributor
Send a message via AIM to MNYPNNY Send a message via Yahoo to MNYPNNY
Way over $30K here....
~~Michelle
'92 LS-L - copper - 190K miles
'94 LS-L - pearlie - 92K miles
*still have '92 parts*
Old 11-09-2007, 06:23 AM
well....i never said that i was proud or happy about spending 30K on fixing the car...i'm sure no one would.
i didn't even get a body job
Old 11-09-2007, 03:39 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Purchase: $3000
Audio: $950
I'm headed over to a mechanic on Wednesday to make sure everything's in proper running order :S
Asides from that I've done one oil change and just put on new brake pads. But umm reading all this is scary lol. I'm thinking of selling.
Old 11-09-2007, 04:04 PM
Originally Posted by IceBlade View Post
Purchase: $3000
Audio: $950
If you take care of your trans, windows, and don't get in an accident you'll be ok. I've replaced two windsheilds, I'm on my 3rd tranny, and I had some sweet body work done.
Old 11-09-2007, 04:08 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
purchase $2000
3 sets of wheels (rx7,rota,sti bbs) $1500
tires $600
seats $200
Visors $50
steering wheel $200
floor mats $80
Exhaust work $600
low mileage engine and seals ($1400) after swap was completed
pwr radiator $500
perrin pulley $120
JDM accesories about $650
poly bushings $40
bumper $500
Paint job $1000 (yes i had a hookup so i only paid for paint)
koni/gc $1500
rad hoses $120
lightweight battery $100
Brake rotors and pads $380
97 grille $120
sound system $400 (which im redoing)
blitz filter $30
tranny cooler $50
tint $120
total $12250 and thats not including alot of misc stuff
[SIGPIC][/SIGPIC]
STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit.
Display Modes
