Old 10-28-2007, 09:05 PM
cruisen_15's Avatar
cruisen_15 cruisen_15 is offline
i have a 96 ecu, but its a diffrent type of hesitation, sounds like im running on 2 cyl's, its really embarrising.....
Old 10-28-2007, 09:24 PM
Nomake Wan's Avatar
Nomake Wan Nomake Wan is offline
Retired
Send a message via AIM to Nomake Wan Send a message via MSN to Nomake Wan Send a message via Yahoo to Nomake Wan Send a message via Skype™ to Nomake Wan
Is it the strange hesitation around 3k RPMs? My car had that too. You'd floor it, the car would rev up... then hit 3k and pause... then continue revving. Shift and repeat.
I fixed this problem by installing the ECUtune Stage 1v5 chip.
Old 10-28-2007, 09:35 PM
cruisen_15's Avatar
nope its not actullay a hesitation but a series of backfiring and bogging.... u floor it and it just completly goes wack.... even mild or easy accel. and itll do it
Old 10-28-2007, 10:06 PM
UPnorth362's Avatar
UPnorth362 UPnorth362 is offline
Send a message via Yahoo to UPnorth362
Maby you should make sure you have the correct ecu for your year.
IT'S 5:00 SOMEWHERE!!!
92 Liquid Silver SVX LS-L
Old 10-28-2007, 10:14 PM
cruisen_15's Avatar
no its correct, it had same symptoms before the new ecu and i had the new ecu baught and installed by a performance subaru shop, it was a brand new ecu btw
Old 10-28-2007, 10:36 PM
UPnorth362's Avatar
would try replacing the MAF sensor, and the TPS. I had a problem with hesitation at specific rpms. I cleaned the MAF and it made the problem better, but didn't completely fix it. Installed a new MAF and everything was golden.
Old 10-28-2007, 10:44 PM
cruisen_15's Avatar
not the maf or tps either, i put a good maf on, not the problem, cleaned and adjusted the tps to .5v, also not the problem.... though my fuel pump makes a nasty squeal on start up....
Old 10-28-2007, 10:54 PM
UPnorth362's Avatar
well that could very well be your problem. If your pump is bad, it will cause erratic behavior. Do you have access to a fuel pressure guage? If the engine is not running properly, it could also cause shifting issues.
Old 10-28-2007, 11:00 PM
cruisen_15's Avatar
i was told by a member here that if im having hesitation that dont change my fuel pump... i had a good fuel pump and everything ready to go till i heard this and bagged the idea, , u got it right, it does shift very weird into 2nd, takes a good 4 seconds at easy throttle to actullay go into gear
Old 10-29-2007, 08:22 AM
EDITED FROM PREVIOUS POST
Also be aware that there is NO POWER LIGHT at startup, because of the OBDII configuration, this is missing on the 96-97 cars
You will still be able to enter POWER mode by mashing the throttle quickly from a stop or while driving, just without the power light to confirm this. Reacts the same as the earlier cars with the power light.
This is normal.
Originally Posted by paulmeisterpk View Post
I've got a '96 as well. I've never seen my power light come on at startup or anytime while I'm driving. My tranny shifts normal, so I'm not worried about it at all. I just figured OBD II cars didn't have a power light.
I went out and double-checked my 96 Polo. There is no POWER light when turning on the ignition or at startup. In bright sunlight you can still see the POWER lettering on the dashboard that used to be illuminated.
I wonder if Subaru just took out the bulb in the OBDII cars. I wonder if it would illuminate the way it used to if a bulb were installed? I can't see a redesign of the instrumemtation circuit just to eliminate one bulb.
Sorry for the confusion on my part in the initial post.
Display Modes
