Yeah, it hit me that we were probably talking past each other, i.e. hydraulic lifter=lash adjuster
![]() So, let's get back to what you've done so far...you've used a stethescope and checked around on the engine and haven't "heard" the sound, so I'm going to say that it's not injector (you have put the 'scope on the top of each injector, right?) or lash adjuster noise (you have put the 'scope on each valve cover, right?), as you'd have heard it through the stethescope. You've checked the flexplate bolts, so it's not a loose flexplate. The noise does change with engine rpm, "going away" at higher rpms. Suggestion - get the car either on a lift or up on jack stands and go back to work with your stethescope. If the sould is audible to the "naked ear", you should be able to pin point it with the stethescope. The good thing is is that there aren't that many things on the EG33 that will make this type of noise. The bad thing is that they're all a PITA to fix ![]() -Bill
-Bill
yes I listened to the sound clip also and my flexplate didnt sound like that. or any other flexplate I have heard (im a ASE cirt tech) and I drove mine till it almost brok all the way free. the sound is going to sound just like a lifter tap. IM going to put all my money on the flex plate. Just pull the trans. total job is about 4 hours or less. the worst part is thoes damn TC bolts
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs |
