Bosch or Walker oxygen sensors
Has anyone ever had any problems with the Bosch or Walker Oxygen sensors? My car has been running pretty poorly for a while. When I did the check engine light routine, the code came up 02 sensor. So I swapped them out for some Walker sensors. They lasted about a week or 2 before the problem re-occured. I swapped them out for the Bosch and it didn't change anything.
I gave up on trying to fix the problem on my own, so I took it to the dealer. The technician said the code is still coming up- bad 02 sensor. So, I should just buy the Subaru 02 sensors @ $1,000,000 a piece, I'm sure, and this should fix the problem. Any advice from anyone would be highly appreciated. And yes I already swapped out the spark plugs. So that probably isn't the cause. Thanks in advance. |
...?? i switched over to bosch o2 sensors..and i would like to think that i dont have problems with them. i swapped them out making the assumption that the car wasn't serviced for 8 years before i bought the car.
but what do you mean of the car running poorly? is that towards rough idle (like my car) bad acceleration, no power.??
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
Try clearing the code and see if it comes back.
Bad O2 sensors don't usually cause crappy driving. It's usually something else.
Define crappy driving? Is it really really bad or it just a little ping?
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
It's a really rough idle that smells really rich. Low power, terrible acceleration, and what sounds like a clicking. A mechanic friend of mine said, it sounds like it's missing. It's a repetitive tapping that just sounds horrible. He said after swapping out the plugs and 02 sensors that it may be some bad injectors. Any ideas?
And I have repeatedly taken the battery in and out and cleared the codes manually. Just trying not to get raped at the dealer. Thanks again. |
I'm betting the O2 sensors are working properly. They are just telling you there is a problem. Could be your timing is off, bad coil(s)/plug(s)/injector(s).
Check for leaks on your cats and exhaust too. That caused my o2 sensors to fail as it would send incorrect signals to the engine computer.
'95 SVX LSI Black, just wire mod. New speakers + homemade front mounts. "In times of peace, a gentleman keeps his sword at his side." Sun Tzu c 300 b.c. |
Ok thanks, I'll have the dealership tech check the cats for leaks. Thanks
The first sensor is the onse that interacts with the ecu and all the other sensors, the 2nd one just measures cat effeciency. nipper |
OK thanks. But, which one is the front 02 sensor? They are the same distance apart-front to back of the car. There is a driver's side and passenger side though.
im learning about SVX from this board, but otherwise am a sooby expert. Other soobies have two, one before and one after. Are you saying there are two O2 sensors before the cats, or is there one befroe the cat, and one after the cat, OR two before and one after.
nipper |
Most SVX's are OBDI and do not have an O2 sensor after the catalytic converter. What year is this SVX?
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock ![]() ![]() |
It's a 92. But thanks I'll have the dealer check the injectors, only because they already have it there. But that makes the most sense so far.
