AC question
Hola.
Are the ac compressors all the same for all the different year svx's? Except for the freon difference in the 92's, could I use a 96 or 97 compressor in my 92? Thanks Danny |
I do know that a 94 and 92 are the same at least physically.
Re: AC question
http://www.subaruparts.com/cart/?pn=73011PA010 If the link don't work, just do what I did and check on the different parts in the diagram. You may have to do a "search" for Compressor on the '92.
yes you can use the same compressor on the svx from92-97 the only thng is that your set up i believe is r-12, drain the compressor oil and flush out the sytem, put sysnthtic pag oil in the compressor unit the amount you took out. alsoarway replace allseal with new nitrat seals. this should be done at a good a/c shop. i charge around $320 for this service. if you have any other q's please ask me
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon |
