Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 04-18-2006, 09:12 AM
The Korean The Korean is offline
Send a message via AIM to The Korean
What would you do for an all around NA Build...
What would you do for an all around NA build? Keep in mind this would be a daily driver and have a 5 speed conversion done already...
I'm looking at the basics right now:
1. CAI
2. Custom exhaust
3. ECUTune Stage 1
4. Pulley Kit
5. Koni Inserts with lowering coilover springs
6. Sway Bars
7. Custom Strut Bars
8. Bigger/wider wheels and tires... Rotas
9. Brake upgrade along with steel lines
10. Nitrous...?
That's about the only things I can think of or that I've seen. But what about more engine modification?
Jonny Walker
Old 04-18-2006, 10:01 AM
Jade Dragon's Avatar
Jade Dragon Jade Dragon is offline
Don't screw with the Dragon
Send a message via AIM to Jade Dragon Send a message via Yahoo to Jade Dragon
I would go ECUtune stage 2v5, get the full setup, maf, fuel regulator, injectors. the works. espically if your going to run nitrous
->Austin<-
1992 Pearlie (Pearl): motorsport exhaust kit (Wife's)
1994 Red FWD (Roxi): Custom X exhaust
Old 04-18-2006, 11:54 AM
drivemusicnow's Avatar
drivemusicnow drivemusicnow is offline
Poor College Racer
Send a message via AIM to drivemusicnow
1. CAI
2. Custom exhaust
3. ECUTune Stage 1
4. Pulley Kit
6. Sway Bars
10. Nitrous...?
Well, CAI is only effective if it actually draws cold air. (read in the fender)
Exhaust can lose horsepower as well, but thats a choice you can make.
I would go with ECUTune stage 2v5 or whatever with the MAF upgrade.
Pulleys are not helpful.
Koni/GC combo is a great option for SVXes
Sways will help, talk to mychailo, Strut bars are pretty worthless, but they're cheap as well.
Wheels and tires are always good.
brakes are always good.
ehh, nitrous if you want.
I would go with camshafts similar to what Tomsvx did.
These are my opinions of course.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 04-18-2006, 12:01 PM
Earthworm's Avatar
Meow!
+1 for cams (before nitrous)
Old 04-18-2006, 12:49 PM
Originally Posted by The Korean
1. 5mt conversion
2. CAI
3. Custom exhaust
4. ECUTune Stage 2v5 w/ Z32 MAF
5. Adjustable FPR and Walbro 255 Fuel pump
6. Delta performance intake cams
7. Koni Inserts with coilover springs
8. Sway Bars and bushings
9. wider/lighter wheels and tires... Rotas(bigger not always better)
10. svxfile's Big Brake upgrade along with steel lines
11. 75 dry shot ZEX nitrous
That should do it
Old 04-18-2006, 01:26 PM
What is a FPR? Fuel Pressure Regulator? Is that kinda like a AFC?
I was thinking about going with 18s.
Is there anything else suspension wise I could do or are the Koni/GC combo the only option?
Thanx for the quick responses...
Jonny Walker
Old 04-18-2006, 01:29 PM
Oh and if this helps the nitrous was an after thought... probably not a first thing to buy and everything would be going on a 92 LS-L.
EDIT: and... is there any real noticable difference between the Stage 1 and Stage 2 ECUtune? Also is a NA build a good idea for a daily driver/ weekend warrior kinda thing? What all would you do the order of things?
Jonny Walker
Old 04-18-2006, 01:35 PM
Earthworm's Avatar
Meow!
The Koni's are a must but there are a few choices for springs.
My theory, upgrade the handling/braking before upgrading the speed.
Old 04-18-2006, 01:39 PM
What are the spring choices... I've only been able to find like 1 or 2...
I have the same theory too...
Jonny Walker
Old 04-18-2006, 01:47 PM
Earthworm's Avatar
Meow!
Well aside from the GC's, Dayle @ Motorsport Warehouse has some or you can go custom with Mychailo's springs.
Old 04-18-2006, 01:55 PM
Ya those are pretty much what I've found. If I go custom I wanna have a rate greater than 200 correct? I'm looking for some sort of spring that will lower the car... alot... 1.5-2" drop (ok, maybe that's too much, but probably around 1.5" more than likely)... along with something really stiff.
Where do I find some Delta Cams?
Jonny Walker
Old 04-18-2006, 02:16 PM
Ok, two more questions for now...
Where do I find Mychailo's springs?
How much does SVXfiles Big Brake Kit cost... and what does it include (and yes I looked in that thread, but couldn't really find anything, lol)?
Jonny Walker
Old 04-18-2006, 02:22 PM
And this is how low I would like to go with the front and the rear...
Jonny Walker
Old 04-18-2006, 02:31 PM
Earthworm's Avatar
Meow!
Search button is your friend:
http://rallyeng.selfip.com:8080/SVX/...ort_parts.html
I don't think it's public as of yet.
The GC's can go that low if you want but I wouldn't recommend it. You wouldn't clear the smallest of speedbumps and parking will kill your front bumper.
Old 04-18-2006, 02:38 PM
Does the ECU Crush mod do anything aka is it worth it?
Jonny Walker
