Old 06-11-2005, 05:53 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
fuel guage
i know it's common on many svx's but is the fouling fuel guage caused by the guage itself or somewhare else?
Old 06-11-2005, 06:15 PM
Earthworm's Avatar
Meow!
I believe it's the sending unit.
Mine never had the problem though.
Old 02-08-2006, 11:58 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Do all SVX's have screwy fuel guages?
When the fuel guage on my '94 hits E, it takes 10.5 gallons to fill up. I know there's another 8 gallons in there. Yesterday I took the '92 garage queen in for it's first fill up. 10.5 gallons. What's up here? I didn't wait for any warning lights. Does it just sit on E for along time?
Gene and Ben
Old 02-08-2006, 01:12 PM
Hangtownsvx Hangtownsvx is offline
It has been surmised based on other Subaru products that the problem is corrosion in the sending unit. For many of us it falls in the too hard basket to really verify and fix.
Old 02-08-2006, 01:39 PM
Earthworm's Avatar
Meow!
Mine started out like that when I bought it. Over the next few fills I would go further and further until it started reading accurate. It's almost as though the sending unit needed to go through its entire range to recalibrate itself.
That's my answer and I'm sticking with it
Old 02-08-2006, 02:53 PM
bwb3's Avatar
Maybe it doesn't understand the U.S. gallon?
Gene and Ben
Old 02-09-2006, 01:04 AM
thundering02's Avatar
thundering02 thundering02 is offline
Giong back to the beaters...
Same here really...I normally started to fill up around 250 miles (13ish gallons) and it slowly started to read for that to be empty but after a few long trips it will reguage to the more appropite 16ish gallons
86 GMC Jimmy Blue and Silver- R.I.P.
87 Integra RS ~228k miles R.I.P.
92 SVX LS-L Perly ~186k R.I.P.
89 240sx se red ~165k miles Gone and unknown
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
85 BMW 325e ~ Gone and unknown
85 Ford Mustang getting engine swap now!
05 Colorado ~108k Daily Driver
Old 02-09-2006, 05:37 AM
dcarrb dcarrb is offline
My fuel gauge is off, too, always reading 3-4 gallons less than actual. It's consistent, though, so it's an inconsenquential issue. Still, I wouldn't press my luck and drive around with the low-fuel light burning based on that assumption.
dcb
Old 02-09-2006, 08:29 AM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
Fuel Gauge not right
This came up on the Yahoo pages some time ago.
After heavy testing {and a lot of taking chances} it was found that, no matter what you get from the gauge, you can count on about another 15 miles once the light comes on.
Even without this in mind, a lot of us have tried to gauge the actual trip of the average SVX.
That turned out to be right at 375 miles before the light comes on, and somewhere around 390 to run the tank dry.
The gauge actually stands on it's head right about there.
I have run mine from slam full {in the neck} to 382 miles before gettin the heeby geebies, and just HAD to fill it up.
BUT. My gauge never got any better. So.
There ya go.
Old 02-09-2006, 10:01 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
What's your exact problem with the fuel gage...just the quick to E 'normal' reading? My legacy gage sometimes would just drop down to E and then below even with a full tank, but that was found to be a very corroded battery connection which I cleaned and everything was back to normal.
1995 Subaru Svx L / AWD
