Old 01-04-2006, 06:01 PM
LiquidForce LiquidForce is offline
Send a message via MSN to LiquidForce
Service Manuals
Any one know a good/cheap place to get the service manual for a 94? I was able to get the service manuals on cd for my WRX for $10 off of ebay. I doubt I'll get that lucky with one for the SVX.
Old 01-04-2006, 06:27 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Send a message via AIM to gest24
I've seen such an item on Ebay. Might be worth a look.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
88 XT6(regret the day I left her behind)
socaleuro.com They like the flat 6...
Check My New Homepage..
Old 01-04-2006, 06:34 PM
Old Fogey
They do come up occasionally on ebay, as well as right here on the FS forum, but you have to be quick. Haven't seen them on CD yet. Expect to pay somewhere around 100-150 for em depending on competition, then you'll most likely need to purchase the updates for your YM from the dealer. The "base" set is for the 92 with an update/correction per year.
Glenn
Old 01-05-2006, 12:55 AM
I have Mitchell on Demand CD's which re very conveinient for getting torque specs, Tightening/loosening sequences, and wiring pin outs. Shoot me a PM if interested. All payments are a fundraiser for the network
Old 01-05-2006, 08:49 AM
intelisevil's Avatar
<<<Alcyone
What exactly is on the CD, how much is it?
Dan
Old 01-05-2006, 08:55 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
I have both Mitchell on Demand and Factory Service paper manuals. The Mitchell on Demand CD is very task oriented, and has good specific information in the form of tables, etc., but it is not nearly as comprehensive as the factory service manuals.
Display Modes
