Go Back   The Subaru SVX World Network > SVX Main Forums > Technical Q & A > Chris's SVX Shop
Old 09-30-2005, 02:19 PM
mid-knight mid-knight is offline
SVX & RXT wagon Owner
Send a message via ICQ to mid-knight Send a message via MSN to mid-knight Send a message via Yahoo to mid-knight
SVX Tranny Conversion
Hi guys,
This is my first time here, Im looking to change my SVX into a stick, the motorsport warehouse told me about you guys and that they dont sell the kit anymore, so.....where should I start here.
Old 09-30-2005, 02:48 PM
Earthworm's Avatar
Meow!
You should start with deciding which tranny you're going to use. The WRX tranny is probably the easiest as you will not have to change/modify the rear differential. The STi 6 speed will not require the driveshaft to be lengthened. Both of these are 3.90 ratios. Most others will be 4.11.
Welcome to the site!
Old 10-02-2005, 03:47 PM
Fuzz541 Fuzz541 is offline
SVXist Pig
Welcome to the SITE! (fixed)
To clarify, the WRX uses a 3.90:1 front differential, a 1.1:1 center differential, and a 3.545:1 (like the SVX) rear differential. The 1.1:1 center diff + the WRX/SVX 3.545 rear = 3.90 to match the WRX front. So your overall final drive will go down a little bit and you will be happily shifting away. Supposedly the 2003+ WRX trannies are stronger than the 2002's. Do some research on this, as it is off the top of my head.
Most other options will require that you source a new rear differential, but that isn't such a bad thing. STi 6 speeds can be had for $3-5,000 on NASIOC.com and eBay. A few folks here have done them.
http://forums.nasioc.com/forums/forumdisplay.php?f=119
Old 10-03-2005, 12:15 PM
Earthworm's Avatar
Meow!
Thanks for the correction. That's the second time I did that. (I corrected myself the first time)
I'm still looking for proof that there's any difference between 2002 and 2003 WRX trannies.
Old 10-03-2005, 03:09 PM
SVXist Pig
Hey, I read it on the intAr3b, so it's true, damnidttt!11!!!!!1one!11!eleven!!1
Something about wider gears in the 03, or was it the 04? There definitely was some kind of issue with the 02's, but only under abuse, from what I understand.
Old 10-03-2005, 04:16 PM
Earthworm's Avatar
Meow!
That's just it, I looked up the gear ratios for both the 2002 and 2003 WRX's and they are exactly the same.
Old 10-03-2005, 04:18 PM
mbtoloczko's Avatar
sans SVX
Originally Posted by Fuzz541
.... Supposedly the 2003+ WRX trannies are stronger than the 2002's. ...
Subaru made a mid-year change in the 2003 WRX 5MT gearbox. 1st and 2nd gear were widened to STi RA v5/6 width. I have verified it by comparing the part numbers of several of the 2003+ gearbox components to the part numbers for v5/6 RA gearbox components.
Mychailo
Visit my locker
Old 10-03-2005, 04:33 PM
Earthworm's Avatar
Meow!
So is there any way to tell which one you have without opening up the tranny?
Old 10-03-2005, 06:19 PM
mbtoloczko's Avatar
sans SVX
If you can get the tranny code off the tranny case, you can probably determine if its an early or late 2003 tranny.
Mychailo
Visit my locker
Old 10-03-2005, 06:53 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
hahh ...maybe that's why my first gear winds up REAL quick ...kinda scary how quick it is. But I have yet to see proof of a difference in actual gear numbers. It seems every website lists the ratios the same as previous model years.
a 5 speed swap definitely makes the car more fun to drive ...didn't think it was possible. You know - I couldn't imagine turbocharging it.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 10-03-2005, 09:05 PM
mbtoloczko's Avatar
sans SVX
The gear ratio is unchanged. Subaru just widened the gears.
Mychailo
Visit my locker
Old 10-04-2005, 05:28 AM
rmjjensen's Avatar
Oh i see ...wow - cool
Rate This Thread:
[IMG] code is Off
