Old 04-08-2005, 10:07 PM
cpelsy2k1
squeeling from under hood
hey guys,
one of my belts is driving me nuts with squeeling,everytime i turn or accelerate it starts squeeling! my dad and I get the feeling it may be scraping the belt cover or it may just need new belts, any ideas? thanks
Old 04-08-2005, 10:44 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
Originally Posted by cpelsy2k1
hey guys,
This is easy to fix. I just love the relative ease of working on Subarus...
As the squealing occurs when you turn or accelerate it sounds like it's the belt that runs from the crank pulley -to- alternator -to- power steering pump -to- idler puley (you made no mention of having your a/c on). The belt just probably needs a little tightening. However, if you see cracks in the rubber, it needs to be replaced.
1) Use a 10mm socket wrench to remove the two bolts that hold the black plastic belt cover in place.
2) Take the closed end of a 14mm wrench and loosen the bolt that holds the idler pulley in place (idler pulley is located directly below the black p/s pump). Loosen the bolt - but no need to take it off completely.
3) There's a tensioner mechanism that runs diagonally upwards from the idler pulley. Use a 12mm wrench to tighten the bolt on the end of the tensioner pulley. As you tighten it up, you should feel the tension in the belt increasing.
4) When you've got the desired tension in the belt, lock the 14mm bolt at the front of the idler pulley down.
5) Replace plastic belt cover.
You're done!
If belt continues to slip slightly, you may want to pick up a $3 can of belt dressing from your local parts store and/or a new belt.
-Chike
2006 Steel Gray WRX TR (sold)
Old 04-08-2005, 10:54 PM
Check your power steering fluid as well. Even with a new belt squealing can come from a gross ps fluid.
Old 04-08-2005, 11:49 PM
Chiketkd's Avatar
Good point Nik Fu. Dirty p/s fluid can cause a squealing sound...
-Chike
Old 04-09-2005, 07:06 PM
STORMINORMAN STORMINORMAN is offline
Lightbulb I'm startin' to sound like a broken record...
...,here! REMEMBER to
Check the crankshaft pulley/harmonic balancer...
Check the crankshaft pulley/harmonic balancer, too!
If the pulley shows silver between the inner metal core (where it bolts on) and the outer metal rings (the surfaces where the belts ride) it is starting to GO (and the place where it goe$ is into the timing belt cover)! If it feels like it is $ticking out a bit it is headed for the radiator, instead!
Much cheaper and much less of a hassle to replace it before it detonates.
Cheers!
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
Old 04-10-2005, 12:51 AM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Send a message via Yahoo to SVX-FF
...(you made no mention of having your a/c on)...
-Chike
It is early April in Minnesota. A/C is only used in the 2nd and 3rd week of August. You are so silly a/c in April..
Steve
j/k about the silly part.
92 SVX AWD 130,000 w/ rebuilt SVX 4.11
97 Audi A4 1.8T (Daily Driver)
03 Ford Expedition(hers)
SVXepidia SVX information warehouse
Are you in?
My Old Locker
A 4.11 Founding Father
"Tranny #6" I really need a manual
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
