Old 03-07-2005, 03:43 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Arrived
Mine arrived today. A few bent fins, but otherwise ok. I will admit, though, that I have seen considerably smoother and uniform welds before.
Cap postion?? In the slot that the cap hold down tabs ride in there is an indented place at the center position. I am pretty sure that this is where the cap should be positioned. You can depress it to take it off OR push it further off center. This would cause the problem previously identifed in here.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
20 F150 4X4 King Ranch
FREEDOM IS NOT FREE
Old 03-08-2005, 12:26 PM
Old Fogey
Got mine Monday evening. In perfect unblemished condition, a thanks to the shipper and PWR for the great packing. It's a work of art!! Is the general consensus to continue to use the auxiliary trans cooler, in addition to the new and improved 5-pass?? Just need those Silicone hoses and a couple of hours. Good opportunity to drain and refil the trans as well. I really don't see the cap as being an issue, as once it's engaged nothing changes as you turn it all the way tight.
Glenn
Old 03-08-2005, 02:27 PM
GTOSVX GTOSVX is offline
Formerly known as broyles
Smile radiator received
UPS delivered Monday evening, box was well packed. there was a rip in the box during shipment, but seems to only affect the foam packing, radiator looks fine. No fins bent, all squared away. My cap is in the same position as it was on my stock radiator, directly parallel with the tank. It was diagonal as received, but when you tighten it to the closed position it is perfect. Will not install till the next weekend due to time constraints, and plan to forgo auxilliary cooler.
thanks again to Chris, et al, tht made this group buy a success.
Old 03-08-2005, 05:51 PM
Hohopirates's Avatar
Hohopirates Hohopirates is offline
Pwr
Yeah, my Cap sits at an angle at full tight. It has started to leave a scratch under my hood.
Steve
Old 03-08-2005, 07:18 PM
lhopp77's Avatar
Tight?
HoHo,
Are you sure you are not moving your radiator cap PAST the correct tight position? I suspect you might be. Is there a place in the middle that is not at tight as when you force it on to the right?
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
FREEDOM IS NOT FREE
Old 03-08-2005, 08:00 PM
Pwr
No it is a little off. When I go to take my cap off after hood has moved it I only have to turn it like 1/4 turn and it releases pressure.
Steve
Old 03-09-2005, 09:16 AM
GreenMarine's Avatar
GreenMarine GreenMarine is offline
From POST-***** to LURKER
Is the group rate still $450?
2020 Subaru Outback Touring - Wife's first Subaru
2005 Volvo V70R - 5-cylinder love! :Heart:
** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned
** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!!
** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love...
Old 03-09-2005, 09:35 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Possibility if any are left. Give em' a call, the number is a few pages back. We've basically lost count from the original 40. I think there are 3 or 4 left.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 03-09-2005, 01:42 PM
AFBeefcake's Avatar
AFBeefcake AFBeefcake is offline
Subaru Swapper
Send a message via AIM to AFBeefcake
just got my today
2005 Legacy GT
2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles
My WRX's Cardomain Page
Old 03-09-2005, 01:51 PM
got mine today and it is beautiful. I am glad I waited but it would have been nice to have it sooner. Anyway, I will not be ijstalling it until the hoses come in. No fins bent on mine everyhting is perfect except the whole cap situation. Will try to pick up a cap with no tabs or just cut mine off.
Old 03-09-2005, 05:09 PM
drxman's Avatar
drxman drxman is offline
Heat damage... Possible?
I have been considering the problem with the cap in contact with the hood...
I have a question for those who have installed the rad in question...
Will a PWR rad, with a challenged clearance at the cap, also be in closer poximity to the hood at the apex of the body of the rad in question? Compared to OEM rad of course...
In other words...
I am wondering about discoleration of paint due to excessive heat from the top of the rad... What is the difference between OEM clearance and PWR clearances at the cap and body?
Thanx
Dr. X
1986 Pont. Grand AM 198k - Rusty but trusty daily commute or public parking drives.
1997 Suzuki X-90 50k - To get to that perfect fishing site or campsite.
1993 Subaru SVX (#006 01/93) 104k - To travel in style and grace.
Old 03-09-2005, 06:18 PM
In other words...
Thanx
Wow.. Good point. Especially in desert climates such as mine.
This "drop in OEM replacement" has a flaw that may be worse than we think.
Robert
Old 03-09-2005, 08:56 PM
Got mine today too. I have not unboxed them yet, but will do that tonight.
Old 03-09-2005, 10:22 PM
Peach
A work of art
After all said and done these units are nice. Doesn't appear cap will be a problem. Packaging was great...welds looked nice. It will be nice to cruise in the summer knowing the rad won't ruin a trip, or engine. Maria supplied a tracking number so you can watch your unit hit your home town via the internet. There's even a nifty pwr decal in the packing slip. It's nice knowing you have one of the 40 units...happy trails
Old 03-09-2005, 10:26 PM
Hood
I don't think the heat will be an issue with the paint. The cap on my radiator does not get that hot and it is only the slight edge of the ear that hits. I don't think it will be an issue.
Steve
It's not a car..it's a boat!!
