Old 02-18-2005, 08:27 AM
Harley01
Stops Running
Help! maybe sumeone can help me out.My SVX stops running has you are going down the road.But then you can start it right back up and it may do it again or not.sumetimes it goes for a day and runs great. It has no codes that come up.Can sumeone help me out. Thanks
Old 02-18-2005, 04:12 PM
lee lee is offline
it's almost certainly something electrical in nature, and quite possibly one of the sensors.
but just to get you started, first find all the ground points and clean them off and reattach (or replace as necessary). BTW, this is more than just the battery ground - although that's a biggie.
many intermitant electrical problems end up being a result of poor grounds.
Old 02-18-2005, 05:13 PM
SEA Sleeper
*puts on thinking cap*
A bad CKP (crank angle sensor) signal will cause the engine to stop running. I would inspect the wire harness and try cleaning off the connector to the sensor. I believe it's located in the front of the block behind/ underneath the altenator.
I am not sure why a trouble code is not present if this is the case however.
You may also check your PCM's (engine computer) power supply and ground.
Just shooting in the dark here but I hope this helps.
Good luck
BTW, what year is your SVX?
Old 02-18-2005, 05:34 PM
mbtoloczko's Avatar
sans SVX
Failing MAF sensor?
Mychailo
Visit my locker
Old 02-18-2005, 07:20 PM
SEA Sleeper
Originally posted by mbtoloczko
Failing MAF sensor?
MAF would also cause a code to be stored and set the MIL (malfunction indication lamp).
Since there is no MIL present, I'm leaning tward PCM ground. As Lee suggested, check all of your grounds. Your (-) battery cable ground wires have back shielding w/ a yellow stripe.
Old 02-18-2005, 07:57 PM
TXCESSVX's Avatar
TXCESSVX TXCESSVX is offline
Cheif Dish & Bottle Washer
My '92 would sometimes die while driving, with no MIP or check engine light.
I found (by wiggling the connector and trying to start it again) that I had a poor connection at the MAF connector. Haven't had that problem since soldering the wires right to the receiving pins.
But it sure was annoying to stall out while driving down the road.
I thought there should be a check engine light. Never did see one, although there is an error code for that problem.
Hope this helps you find your problem.
Old 02-24-2005, 08:20 AM
Harley01
Thanks Guys i'll give that a try.
Old 02-25-2005, 03:21 AM
Harley, i was thinking.... is your battery good? your case may be as simple as a battery case....
Display Modes
