Speedometer quit
While testing cruise control functionality in my SVX my speedo decided to quit. My first instinct was to check the speed sensor. It's securely plugged in. I do not get a check engine light.
Anyone have any ideas as to what order I should be checking for problems? I'm going on a long trip in 2 days so this is very important. BTW, this is with the 5MT from a 2002 WRX. (should I be pulling out my dash?)
sounds like vss1 to me. Did it work after the 5 speed swap? I dont know the shade-tree way to diagnose this with anything other than a high end DMM with a frequency input (to count pulses or a small ociliscope) or the Subaru Select Monitor. Will ask Chris Debban for you tonight.
-- Chris Founder/Administrator SVX World Network ECU Tune (stage 1), PWR (prototype aluminum radiator) Amateur Radio - General Class - K7SVX #1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed) #2 92 Teal LSl 125k (Retired, car rescued from a field of weeds) 2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver) 2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler) 1985 Honda VF500 Interceptor (fair weather fun commuter) Going on 11 years of NHRA bracket racing NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com) 2000 1st Place Club Challenge Series 2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway) 2003 4th Place Season Track Champion, Import Racing (Firebird Raceway) 2003 1st Place NW Regional Import Shootout (July 5th) 2004 1st Place Club Challenge #1 (Firebird Raceway) 2004 1st Place NHRA "King of the Track" race 2004 NHRA Gold Cup 2nd place season win 2004 Import/Sport Compact 3rd place season win 2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC) 2007 1st Place Import Survival #3 2007 1st Place Track Champion Import Summer Jam (Wild Street Class) 2007 1st Place Import Survival #5 2008 Club season 1st place win, Club Champion 2008 2nd Place Season Import Final. 2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or) 2009 2nd Place Import Summer Jam (Wild Street Class) 2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2 |
Yeah, it's been working great for a year and only quit yesterday.
The problem started when I was playing with the wire you're supposed to ground to fool the ECU into thinking you're in neutral and preventing high idle. The only problem with doing this is that you lose your cruise control ability. (on mine anyway) The only thing that may have caused this was that I went to shift into 4th but may have been hitting R instead (slight grind). All the gears still work perfectly.
First eliminate vss2. with someone in the drivers seat unscrew vss2 and spin it with the ignition on if speedo jumps it's the vss2 gears.
Any update worm?
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
What comes out with VSS2 ?
Hi,
So, when I unscrew my VSS2... what will come out with it ? My Speedo,Odo,Cruise crapped out (engine codes show VSS2 and O2 and EGR all at once - weird). If I remove, I wanted to check if its the speedo gear or just the sensor ??? |
The speedo stopped working while you were driving the car?
There is a T shaped protrusion from the bottom of the sensor, it is driven by an axle. It's kind of like how a flathead screwdriver fits into a screw. If you take it out you don't have to be afraid of stuff flying everywhere.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 03-14-2007 at 05:17 PM. |
Great answer and pic !
Next question would be how do I get the 'shaft' out ? |
If your problem is the speedo gears you have to drop the transmission and seperate it from the diff. to change the gear. I hate to be the bearer of bad news. I had mine done earlier this year and it cost me $400, a stripped stud and lug nut, scratched rim, broken antenna and a pair of clips for the H-6 engine cover. Whats worse is that it was one year after I had them put in a new diff. (a day after the warranty ended)
Thanks for the bad news, but I'll just use my Tach for the Speeds if the VSS2 doesn't fix it. No way I'm spending that much for a damn little gear ! Which controls the Speedo, Odo, and Cruise: VSS1 or VSS2 ? Which is which mounted on the Tranny. I can find one that's seen thru the engine compartment, next to the tranny dipstick . Last edited by RobSVX; 12-22-2004 at 04:38 PM. |
If i'm not mistaken it also messes up your ability to go beyond a 90/10 power distribution, it causes an error code no speed sensitive wipers or speed sensitive steering and you'll get hassled when you get your next inspection for mileage. Yes it is a poor design.
How 2 Check the VSS1 ?
I've seen how to check the VSS2, but how about the other at the tail shaft ?
The Trouble Code check threads didn't mention, a code for a faulty VSS1 that I could find ? |
vss1 and vss2 error codes are 32 and 33 respectively.
Actually, Code 32 is for the O2 Sensor - Passenger side.
What's the code, if any, for the VSS1 ? Thx ! Last edited by RobSVX; 12-23-2004 at 07:30 AM. |
Thread Tools | |
Display Modes | |
