View Poll Results: What clutch are you using? | |||
Stock cable operated |
0 | 0% |
Aftermarket cable operated |
1 | 20.00% |
Stock hydrolic operated |
1 | 20.00% |
Aftermarket hydrolic operated |
3 | 60.00% |
Voters: 5. You may not vote on this poll |
Thread Tools | Display Modes |
Clutch Curiosity
Just want to know what all the 5 speeders are using for a clutch.
I got an ATC that seams to handel drag launches well. (better than the tranny)
![]() Not sure what I'm gonna run with the six speed yet ![]()
Exedy 13.5 lb flywheel, Exedy Sport clutch disk (organic) and pressure plate. Worked well until I smoked it once in a drag launch. Now it shudders badly in the morning. Going to try an ACT flywheel and clutch next time.
Mine used to shudder every once in a while (in the morning as well).
Mine slipped once during an autox (Sept 18/19) and hasn't shuddered since ![]()
